Date/Time: Sun, 28 Apr 2024 06:43:19 +0000
Invert dom price ladder
View Count: 3086
[2013-03-21 18:20:01] |
tr726 - Posts: 30 |
Is there a way to invert the dom price ladder?
[2013-03-21 20:15:45] |
Yes. By altering the Chart >> Chart Settings >> Advance Settings 2 >> Real-time Price Multiplier and making it a negative number.
[2013-03-22 01:54:40] |
tr726 - Posts: 30 |
Works great!!! thx for the quick response!
[2013-03-22 19:40:13] |
tr726 - Posts: 30 |
now that my dom is inverted the volume by price is no longer working.
[2013-03-22 19:42:47] |
Try setting the Historical Price Multiplier as well.
[2013-03-22 20:07:29] |
tr726 - Posts: 30 |
works great!! thx...
