Date/Time: Sun, 19 May 2024 02:03:04 +0000
rEMOVING THE BACKGROUND COLOR ON TEXT
View Count: 417
[2020-05-09 00:03:35] |
User925659 - Posts: 39 |
Hey How do I turn off the orange background and just have the text?
SIERRA BACKGROUND BLOCK.PNG / V - Attached On 2020-05-09 00:01:20 UTC - Size: 3.75 KB - 167 views Attachment Deleted. |
[2020-05-09 01:50:56] |
What is the functionality in Sierra Chart which is drawing that text? Where did you enable that?
