Date/Time: Mon, 29 Apr 2024 00:02:08 +0000
SC Real-time and Historical Data Feed and IB Symbols
View Count: 1107
[2014-01-20 13:26:02] |
User94740 - Posts: 333 |
Hi SC, should I understand the new data feed also supports the symbol logic from IB?
[2014-01-20 16:11:36] |
Yes. There is mapping of the Interactive Brokers symbols to the Sierra Chart symbols for the symbols that the Sierra Chart data feed supports.
[2014-01-20 16:39:12] |
does this mean I can use a conventional eg b6h14 instead of gbp-201403-GLOBEX and be able to trade as well from the chart b6h14 with IB?
[2014-01-20 17:00:32] |
No. You must use the Interactive Brokers symbols. They will be properly mapped to the Sierra Chart data feed format.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-20 17:00:59
