Date/Time: Sun, 19 May 2024 06:59:15 +0000
Various Issues
View Count: 477
[2020-05-08 14:09:18] |
User472511 - Posts: 19 |
Hello, I have noticed numerous issues in the latest pre-release (2101). -Using the scroll wheel to zoom in/out seems to be broken and requires me to use the "go to end of chart" hotkey anytime I change the zoom level. -Since the new chartbook format has been implemented it seems that certain parameters under "chart > graphics settings - chart" are not being respected even when "use global graphics settings instead of these settings" is unchecked. For instance, the "chart trading order fills entry/exit connecting lines" show the same color for primary and secondary no matter if they are set to different colors. -When using constant range under scale settings upon saving and re-opening the chartbook this defaults to "keep last bar within view" no matter what setting it was saved with before closing. I have tested all of these with new charts built from the bottom up and there has been no fix available. Please advise. |
[2020-05-09 02:09:08] |
1. There is new functionality with the scroll wheel to change spacing and keep the bar being pointed to at the same location. We will add an option for it. 2. We definitely cannot reproduce any problem like this. 3. We will resolve this in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
