Date/Time: Sun, 19 May 2024 14:54:36 +0000
control board not displaying correct colors on certain days
View Count: 474
[2020-05-07 18:20:10] |
User863099 - Posts: 8 |
I have included a screen shot of the highlighted areas that are suppose to be white. Some days they are the correct colors, like on 5-4-2020 they were. But for the rest of the week they are not.
toolboardnotdisplayingcorrectcolors.png / V - Attached On 2020-05-07 18:19:32 UTC - Size: 20.14 KB - 195 views |
[2020-05-07 20:40:29] |
This does not make sense. The colors are not going to change unless you change them or a Control Bar button is depressed. To control the colors for buttons, refer to: Control Bar: Control Bar Button Properties We are also preparing documentation for controlling the color of other areas of the Control Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-07 21:09:36] |
Obviously I changed those three buttons to white. The problem is that on certain days they are not white. And certain days they are like on 5-4-2020 they were white all day, then I log into green charts next and every day after that and they are not white, they are the color that is in the screen shot I sent you.
[2020-05-11 11:30:07] |
Perhaps an ACSIL custom study you are using is changing the color. Otherwise, there is no reason for them to be changing like you are describing. Here is the documentation for setting the colors of Control Bar buttons manually: Control Bar: Control Bar Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-11 11:30:13
