Date/Time: Sat, 27 Apr 2024 23:15:26 +0000
E-mini real time data with TDAmeritrade
View Count: 1168
[2014-01-20 02:23:02] |
tbwebb2 - Posts: 19 |
I am trying to get a real time chart of the E-mini S&P in SC. I purchased the SC usage time, and also the SC Real Time & Historical Futures Data Feed. I set up an account with TD Ameritrade without depositing any money into it yet. Then I followed the setup instructions shown here: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php When I go to Find Symbol, it only shows: Australian Dollar British Pound Eur/US Dollar E-mini Gold Futures Gasoline RBOB I thought the E-mini S&P500 would be shown here. Why isn't it? Thanks |
[2014-01-20 02:39:03] |
This is very odd. Could you perform a Full Reset of the Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps Also you will need to deposit money into your TD Ameritrade account. You will need to have at least 500 USD in there. This is a CME requirement. We have not yet imposed any requirement on this, but we will in a few more days. If this is not the case, your data feed account will have to be canceled at the end of the month as it is not compliant with exchange rules. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-20 02:39:35
[2014-01-20 02:59:26] |
That worked, thanks! And will work on getting funds deposited.
