Date/Time: Sun, 19 May 2024 10:21:16 +0000
Bid & Ask Depth Bars source code
View Count: 837
[2020-05-04 15:18:58] |
onnb - Posts: 661 |
Is it possible for you to make "Bid & Ask Depth Bars" source code available?
[2020-05-04 19:23:05] |
No, this code would not be usable in ACSIL. And ACSIL does not yet have access to the functionality that this study uses.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-04 19:23:17
[2020-05-04 22:05:34] |
User311344 - Posts: 136 |
Any ETA on access to this data from ACSIL? It was promised quite a while back. Do you plan on delivering only OHLC data for this study or will we get access to new depth structure thats below this study? I guess it would be an asynchronous feed requiring batch reading of records existing between chart update intervals, same as T&S data? BTW I see that study is very often updating previous bar which was already plotted which is not that cool. I wonder if you want to improve that study before you release the access to its data or it will be never possible due to logic of depth data structure. |
[2020-05-11 18:11:28] |
onnb - Posts: 661 |
Is that indeed the case? How do you see this? |
[2020-05-11 18:53:10] |
Well to enhance the effect set your chart to 1sec, chart update interval to 10ms and bar spacing to 20 and you will see it every single depth bar. You will see it clearly with your naked eye. Every previous bar is reploted with different OHLC.
[2020-05-11 22:26:41] |
onnb - Posts: 661 |
Nice, you are right, I can see that clearly
