Date/Time: Sun, 19 May 2024 07:52:03 +0000
CPU Exception after update
View Count: 866
[2020-05-04 13:16:54] |
User92899 - Posts: 73 |
Hi - a client raised this problem. With the latest version a warning: CPU Exception. This custom DLL study may cause Sierra Charts to be unstable until you remove the study from your chart. My Sierra was on v2086 and working fine - I updated to the latest and I also received this error. I rolled back and all was well. Has there been some change to your system that we will have to make changes to our study? |
[2020-05-04 13:59:30] |
Ackin - Posts: 1865 |
Try this: Latest SC version - doesn't like user contributed study | Post: 217184 |
[2020-05-04 15:51:52] |
Hi - I have updated with the additional components but I am getting the same messages across the 3 studies. As I have several chartbooks each with several charts, removing and reapplying the studies to each one is a task too far for our users. There must be another way to approach this. What have you done to the system that this problem has suddenly occurred? I have Onn - the guy who wrote the studies - lined up to make any required changes, as I do not want to be trying to respond to hundreds of emails with instructions as to how to fix this. |
[2020-05-04 18:35:13] |
We need the exact error message from the Message Log. Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) What have you done to the system that this problem has suddenly occurred? We are not sure what the cause of the problem is. It could be related to the use of the old persistent variable data structure, which is no longer provided but has been out of date for many years now.
[2020-05-04 18:58:41] |
Here is the log after about 30 seconds after booting. The error messages will repeat ad infinitum Reading Internal Order ID file. | 2020-05-04 19:56:30.692 Reading Trade Orders file. | 2020-05-04 19:56:31.034 Reading Trade Positions file. | 2020-05-04 19:56:31.034 Reading Account Balance file. | 2020-05-04 19:56:31.034 UDPListener (1308). Port 22903 | Listening on UDP port 22903. | 2020-05-04 19:56:31.102 Software version: 2098 64-bit | 2020-05-04 19:56:31.102 Primary Thread ID: 9788 | 2020-05-04 19:56:31.102 Enabled for: Advanced Features 2. | 2020-05-04 19:56:31.102 Enabled for: Sierra Chart Historical Data Service. | 2020-05-04 19:56:31.102 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-05-04 19:56:31.102 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-05-04 19:56:31.102 Current selected Data/Trading service: SC Data - All Services | 2020-05-04 19:56:31.102 Custom symbol settings values: disabled | 2020-05-04 19:56:31.102 Chart Update Interval: 500 | 2020-05-04 19:56:31.102 Intraday Data Storage Time Unit: 1 | 2020-05-04 19:56:31.102 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2020-05-04 19:56:31.102 2020-05-04 19:56:31 Local computer time | 2020-05-04 19:56:31.102 2020-05-04 18:56:31 Local computer time in UTC | 2020-05-04 19:56:31.102 2020-05-04 19:56:31 Local computer time in SC Time Zone | 2020-05-04 19:56:31.102 2020-05-04 18:56:29 Server time in UTC | 2020-05-04 19:56:31.102 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-05-04 19:56:31.102 Program path: C:\SierraChart\ | 2020-05-04 19:56:31.102 Data Files path: C:\SierraChart\Data\ | 2020-05-04 19:56:31.102 OS Version Number: 10.0 | 2020-05-04 19:56:31.102 Locale Setting: C | 2020-05-04 19:56:31.102 DLLs: ACTS.dll, ACTS_64.dll, NewWizard.dll, NewWizard_64.dll, ProjectX.dll, ProjectX_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-05-04 19:56:31.102 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-04 19:57:42.466 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.466 * Warning: The Custom DLL study "ProjectX.scsf_projectx2" has just caused a CPU exception. | 2020-05-04 19:57:42.589 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.589 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-04 19:57:42.592 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.592 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-04 19:57:42.685 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.685 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-04 19:57:42.686 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.686 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-04 19:57:42.687 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.687 * Warning: The Custom DLL study "ProjectX.scsf_projectx2" has just caused a CPU exception. | 2020-05-04 19:57:42.700 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.700 * Warning: The Custom DLL study "ProjectX.scsf_projectx2" has just caused a CPU exception. | 2020-05-04 19:57:42.904 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.904 * Warning: The Custom DLL study "ProjectX.scsf_projectx2" has just caused a CPU exception. | 2020-05-04 19:57:42.927 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.927 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-04 19:57:42.927 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.927 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-04 19:57:42.939 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-04 19:57:42.939 * Date Time Of Last Edit: 2020-05-04 19:47:02
[2020-05-04 19:47:54] |
Are you able to have the developer of these custom studies look into this now? It is not possible from our perspective to know what the issue is. The developer will need to do the testing and let us know or we would need to get the source code to test it ourselves. Who is the developer?
[2020-05-05 02:44:27] |
We are following up with the developer of your custom studies about this.
[2020-05-06 20:03:46] |
Have you figured out between you what needs to be done?
[2020-05-07 02:24:25] |
Yes we understand what the problem is and we are going to build new DLLs for you and those should be ready in about a day or two. We apologize for the delay. We are taking care of this as quickly as possible although we want to do it right.
[2020-05-07 06:47:18] |
Thank you!
[2020-05-09 01:34:07] |
This is now resolved. The new DLLs are available for your users. They will get them when they restart Sierra Chart. But they need version 2101 to use them. Your users can immediately update by selecting Help >> Download Prerelease. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-09 08:58:58] |
Well, I downloaded the pre-release and it set up 2102. However I still get a big list of warnings in my log, and 3 of the 4 chart sets seem to have no signals on them, which is very unusual. Here's the log: Reading Internal Order ID file. | 2020-05-09 09:53:06.397 Reading Trade Orders file. | 2020-05-09 09:53:06.561 Reading Trade Positions file. | 2020-05-09 09:53:06.561 Reading Account Balance file. | 2020-05-09 09:53:06.562 UDPListener (1412). Port 22903 | Listening on UDP port 22903. | 2020-05-09 09:53:06.604 Software version: 2102 64-bit | 2020-05-09 09:53:06.604 Primary Thread ID: 8476 | 2020-05-09 09:53:06.604 Enabled for: Advanced Features 2. | 2020-05-09 09:53:06.604 Enabled for: Sierra Chart Historical Data Service. | 2020-05-09 09:53:06.604 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-05-09 09:53:06.604 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-05-09 09:53:06.604 Current selected Data/Trading service: SC Data - All Services | 2020-05-09 09:53:06.604 Custom symbol settings values: disabled | 2020-05-09 09:53:06.604 Chart Update Interval: 500 | 2020-05-09 09:53:06.604 Intraday Data Storage Time Unit: 1 | 2020-05-09 09:53:06.604 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2020-05-09 09:53:06.605 2020-05-09 09:53:06 Local computer time | 2020-05-09 09:53:06.605 2020-05-09 08:53:06 Local computer time in UTC | 2020-05-09 09:53:06.605 2020-05-09 09:53:06 Local computer time in SC Time Zone | 2020-05-09 09:53:06.605 2020-05-09 08:53:05 Server time in UTC | 2020-05-09 09:53:06.605 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-05-09 09:53:06.605 Program path: C:\SierraChart\ | 2020-05-09 09:53:06.605 Data Files path: C:\SierraChart\Data\ | 2020-05-09 09:53:06.605 OS Version Number: 10.0 | 2020-05-09 09:53:06.605 Locale Setting: C | 2020-05-09 09:53:06.605 DLLs: ACTS.dll, ACTS_64.dll, NewWizard.dll, NewWizard_64.dll, ProjectX.dll, ProjectX_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-05-09 09:53:06.605 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-05-09 09:53:06.606 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:06.671 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:06.707 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-05-09 09:53:06.707 Received 5 login tokens. | 2020-05-09 09:53:06.758 Symbol settings MD5 received. Request ID: 1. | 2020-05-09 09:53:09.522 Symbol settings are up-to-date for scdataallservices. | 2020-05-09 09:53:09.522 Files to Open on Start up | Opening file: ACTS.cht | 2020-05-09 09:53:09.820 Loading DLL C:\SierraChart\Data\ACTS_64.dll | 2020-05-09 09:53:09.826 HGN20 [CV] Daily #1 | Reloading chart. | 2020-05-09 09:53:09.840 HGN20 [CV] Daily #1 | Performing historical Daily data download for symbol HGN20 starting at last date in file. | 2020-05-09 09:53:09.884 Starting DelayedDownloadMonitoringTimer | 2020-05-09 09:53:09.884 Starting HDTimeoutTimer | 2020-05-09 09:53:09.884 Added historical Daily data request for HGN20 to the queue. | 2020-05-09 09:53:09.885 Triggering next historical data download in queue. | 2020-05-09 09:53:09.885 HGN20 [CV] Daily #1 | Waiting for historical downloads to complete with the IDs: 1, | 2020-05-09 09:53:10.322 SIN20 [CV] Daily #2 | Reloading chart. | 2020-05-09 09:53:10.336 SIN20 [CV] Daily #2 | Performing historical Daily data download for symbol SIN20 starting at last date in file. | 2020-05-09 09:53:10.382 Added historical Daily data request for SIN20 to the queue. | 2020-05-09 09:53:10.382 SIN20 [CV] Daily #2 | Waiting for historical downloads to complete with the IDs: 2, | 2020-05-09 09:53:10.821 ZLN20 [CV] Daily #3 | Reloading chart. | 2020-05-09 09:53:10.835 ZLN20 [CV] Daily #3 | Performing historical Daily data download for symbol ZLN20 starting at last date in file. | 2020-05-09 09:53:10.870 Added historical Daily data request for ZLN20 to the queue. | 2020-05-09 09:53:10.871 ZLN20 [CV] Daily #3 | Waiting for historical downloads to complete with the IDs: 3, | 2020-05-09 09:53:11.317 CLM20 [CV] Daily #4 | Reloading chart. | 2020-05-09 09:53:11.333 CLM20 [CV] Daily #4 | Performing historical Daily data download for symbol CLM20 starting at last date in file. | 2020-05-09 09:53:11.435 Added historical Daily data request for CLM20 to the queue. | 2020-05-09 09:53:11.435 CLM20 [CV] Daily #4 | Waiting for historical downloads to complete with the IDs: 4, | 2020-05-09 09:53:11.903 CCN20 [CV] Daily #5 | Reloading chart. | 2020-05-09 09:53:11.917 CCN20 [CV] Daily #5 | Performing historical Daily data download for symbol CCN20 starting at last date in file. | 2020-05-09 09:53:11.956 Added historical Daily data request for CCN20 to the queue. | 2020-05-09 09:53:11.956 CCN20 [CV] Daily #5 | Waiting for historical downloads to complete with the IDs: 5, | 2020-05-09 09:53:12.400 GCM20 [CV] Daily #7 | Reloading chart. | 2020-05-09 09:53:12.433 GCM20 [CV] Daily #7 | Performing historical Daily data download for symbol GCM20 starting at last date in file. | 2020-05-09 09:53:12.477 Added historical Daily data request for GCM20 to the queue. | 2020-05-09 09:53:12.477 GCM20 [CV] Daily #7 | Waiting for historical downloads to complete with the IDs: 6, | 2020-05-09 09:53:12.935 Files to Open on Start up | Opening file: NewWizardEOD.cht | 2020-05-09 09:53:12.949 Loading DLL C:\SierraChart\Data\NewWizard_64.dll | 2020-05-09 09:53:12.971 UK100 Daily #1 | Reloading chart. | 2020-05-09 09:53:12.985 GER30 Daily #2 | Reloading chart. | 2020-05-09 09:53:13.003 FRA40 Daily #3 | Reloading chart. | 2020-05-09 09:53:13.021 US30 Daily #4 | Reloading chart. | 2020-05-09 09:53:13.039 NAS100 Daily #5 | Reloading chart. | 2020-05-09 09:53:13.058 SPX500 Daily #6 | Reloading chart. | 2020-05-09 09:53:13.125 Files to Open on Start up | Opening file: NewWizardIntraday.cht | 2020-05-09 09:53:13.139 GER30 5 Min #2 | Reloading chart. | 2020-05-09 09:53:13.172 US30 5 Min #4 | Reloading chart. | 2020-05-09 09:53:13.190 NAS100 5 Min #5 | Reloading chart. | 2020-05-09 09:53:13.205 SPX500 5 Min #6 | Reloading chart. | 2020-05-09 09:53:13.258 UK100 5 Min #1 | Reloading chart. | 2020-05-09 09:53:13.271 FRA40 5 Min #3 | Reloading chart. | 2020-05-09 09:53:13.284 Files to Open on Start up | Opening file: ProjectX.cht | 2020-05-09 09:53:13.296 Loading DLL C:\SierraChart\Data\ProjectX_64.dll | 2020-05-09 09:53:13.320 EURUSD 5 Min #1 | Reloading chart. | 2020-05-09 09:53:13.589 AUDUSD 5 Min #3 | Reloading chart. | 2020-05-09 09:53:13.603 GBPUSD 5 Min #4 | Reloading chart. | 2020-05-09 09:53:13.617 EURGBP 5 Min #2 | Reloading chart. | 2020-05-09 09:53:13.783 Mapping HGN20 to HGN20. Service code: comex | 2020-05-09 09:53:13.884 HD Request # 1 | Downloading Historical Daily chart data for HGN20. Starting date: 2020-05-06. Service: scdataallservices | 2020-05-09 09:53:13.888 HD Request # 1 | Requesting historical Daily data for HGN20 starting at 2020-05-05 | 2020-05-09 09:53:13.888 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:13.890 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:13.890 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:13.890 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:13.890 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:13.891 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:13.891 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:13.892 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:13.892 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:13.893 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:13.893 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:13.894 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:13.894 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.548 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.548 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.549 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.549 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.550 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.550 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.552 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.552 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.554 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.554 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.555 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.556 * Starting DelayedDownloadMonitoringTimer | 2020-05-09 09:53:14.754 Starting HDTimeoutTimer | 2020-05-09 09:53:14.754 Added historical Daily data request for UK100 to the queue. | 2020-05-09 09:53:14.754 Triggering next historical data download in queue. | 2020-05-09 09:53:14.754 Using Bid/Ask average for last trade price for UK100 | 2020-05-09 09:53:14.754 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:14.755 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.755 * HD Request # 2 | Downloading Historical Daily chart data for UK100. Starting date: 2020-05-05. Service: fxcm | 2020-05-09 09:53:14.759 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:14.759 Socket (2) | Creating socket. | 2020-05-09 09:53:14.759 Socket (2) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:14.759 Added historical Daily data request for GER30 to the queue. | 2020-05-09 09:53:14.760 Triggering next historical data download in queue. | 2020-05-09 09:53:14.760 Using Bid/Ask average for last trade price for GER30 | 2020-05-09 09:53:14.760 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:14.761 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.761 * Added historical Daily data request for FRA40 to the queue. | 2020-05-09 09:53:14.761 Triggering next historical data download in queue. | 2020-05-09 09:53:14.761 Using Bid/Ask average for last trade price for FRA40 | 2020-05-09 09:53:14.761 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:14.762 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.762 * Added historical Daily data request for US30 to the queue. | 2020-05-09 09:53:14.762 Triggering next historical data download in queue. | 2020-05-09 09:53:14.762 Using Bid/Ask average for last trade price for US30 | 2020-05-09 09:53:14.762 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:14.762 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.762 * Added historical Daily data request for NAS100 to the queue. | 2020-05-09 09:53:14.762 Triggering next historical data download in queue. | 2020-05-09 09:53:14.762 Using Bid/Ask average for last trade price for NAS100 | 2020-05-09 09:53:14.762 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:14.763 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.763 * Added historical Daily data request for SPX500 to the queue. | 2020-05-09 09:53:14.763 Triggering next historical data download in queue. | 2020-05-09 09:53:14.763 Using Bid/Ask average for last trade price for SPX500 | 2020-05-09 09:53:14.763 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:14.763 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.763 * Added historical Intraday data request for GER30 to the queue. | 2020-05-09 09:53:14.764 Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2020-05-09 09:53:14.764 Triggering next historical data download in queue. | 2020-05-09 09:53:14.764 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.764 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.764 * Added historical Intraday data request for NAS100 to the queue. | 2020-05-09 09:53:14.764 Intraday data recording state for symbol NAS100 is set to download 'Pending'. | 2020-05-09 09:53:14.764 Triggering next historical data download in queue. | 2020-05-09 09:53:14.765 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.765 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.765 * Added historical Intraday data request for US30 to the queue. | 2020-05-09 09:53:14.765 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2020-05-09 09:53:14.765 Triggering next historical data download in queue. | 2020-05-09 09:53:14.765 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.765 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.765 * Added historical Intraday data request for SPX500 to the queue. | 2020-05-09 09:53:14.766 Intraday data recording state for symbol SPX500 is set to download 'Pending'. | 2020-05-09 09:53:14.766 Triggering next historical data download in queue. | 2020-05-09 09:53:14.766 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.766 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.766 * Added historical Intraday data request for FRA40 to the queue. | 2020-05-09 09:53:14.766 Intraday data recording state for symbol FRA40 is set to download 'Pending'. | 2020-05-09 09:53:14.766 Triggering next historical data download in queue. | 2020-05-09 09:53:14.766 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.766 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.766 * Added historical Intraday data request for UK100 to the queue. | 2020-05-09 09:53:14.766 Intraday data recording state for symbol UK100 is set to download 'Pending'. | 2020-05-09 09:53:14.766 Triggering next historical data download in queue. | 2020-05-09 09:53:14.766 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:14.767 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:14.767 * Using Bid/Ask average for last trade price for EURUSD | 2020-05-09 09:53:14.767 Added historical Intraday data request for EURUSD to the queue. | 2020-05-09 09:53:14.767 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2020-05-09 09:53:14.767 Triggering next historical data download in queue. | 2020-05-09 09:53:14.767 Using Bid/Ask average for last trade price for AUDUSD | 2020-05-09 09:53:14.769 Added historical Intraday data request for AUDUSD to the queue. | 2020-05-09 09:53:14.770 Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2020-05-09 09:53:14.770 Triggering next historical data download in queue. | 2020-05-09 09:53:14.770 Using Bid/Ask average for last trade price for GBPUSD | 2020-05-09 09:53:14.772 Added historical Intraday data request for GBPUSD to the queue. | 2020-05-09 09:53:14.773 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2020-05-09 09:53:14.773 Triggering next historical data download in queue. | 2020-05-09 09:53:14.773 Using Bid/Ask average for last trade price for EURGBP | 2020-05-09 09:53:14.779 Added historical Intraday data request for EURGBP to the queue. | 2020-05-09 09:53:14.779 Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2020-05-09 09:53:14.779 Triggering next historical data download in queue. | 2020-05-09 09:53:14.779 HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:15.059 HD Request # 2 | Sending historical data logon request message. | 2020-05-09 09:53:15.059 HD Request # 1 | Receiving historical Daily data for HGN20 starting at 2020-05-06 | 2020-05-09 09:53:15.482 HD Request # 1 | Writing historical Daily data to the file HGN20.dly | 2020-05-09 09:53:15.483 HD Request # 1 | Received 4 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for HGN20 | 2020-05-09 09:53:15.500 HD Request # 1 | Completion time: 2s | 2020-05-09 09:53:15.500 HD Request # 1 | Daily data download complete for HGN20. Unique request ID: 1 | 2020-05-09 09:53:15.500 Removing historical data download ID 1. | 2020-05-09 09:53:15.500 Triggering next historical data download in queue. | 2020-05-09 09:53:15.500 Mapping SIN20 to SIN20. Service code: comex | 2020-05-09 09:53:15.570 HD Request # 3 | Downloading Historical Daily chart data for SIN20. Starting date: 2020-05-06. Service: scdataallservices | 2020-05-09 09:53:15.573 HD Request # 3 | Requesting historical Daily data for SIN20 starting at 2020-05-05 | 2020-05-09 09:53:15.573 HD Request # 2 | Requesting historical Daily data starting at 2020-05-05. | 2020-05-09 09:53:15.690 HD Request # 2 | Decompressing data. | 2020-05-09 09:53:15.807 HD Request # 2 | Receiving historical Daily data for UK100 starting at 2020-05-05 | 2020-05-09 09:53:15.813 HD Request # 2 | Writing historical Daily data to the file UK100.dly | 2020-05-09 09:53:15.816 HGN20 [CV] Daily #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-05-09 09:53:15.856 HGN20 [CV] Daily #1 | Reloading chart. | 2020-05-09 09:53:15.858 Socket (2) | CloseSocket call. | 2020-05-09 09:53:15.872 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:15.872 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:15.989 Socket (2) | Closed. | 2020-05-09 09:53:15.989 Historical data download thread signaled to stop. | 2020-05-09 09:53:16.437 HD Request # 2 | Received 3 records from 2020-05-05 00:00:00 to 2020-05-07 00:00:00 (3.0 days) and wrote 3 records for UK100 | 2020-05-09 09:53:16.437 HD Request # 2 | Completion time: 2s | 2020-05-09 09:53:16.437 HD Request # 2 | Daily data download complete for UK100. Unique request ID: 7 | 2020-05-09 09:53:16.437 Removing historical data download ID 7. | 2020-05-09 09:53:16.437 Triggering next historical data download in queue. | 2020-05-09 09:53:16.437 HD Request # 4 | Downloading Historical Daily chart data for GER30. Starting date: 2020-05-06. Service: fxcm | 2020-05-09 09:53:16.440 HD Request # 4 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:16.440 SC Data - All Services | Connected to data server. | 2020-05-09 09:53:16.440 Triggering next historical data download in queue. | 2020-05-09 09:53:16.441 Socket (1) | Creating socket. | 2020-05-09 09:53:16.441 Triggering next historical data download in queue. | 2020-05-09 09:53:16.441 Triggering next historical data download in queue. | 2020-05-09 09:53:16.441 Triggering next historical data download in queue. | 2020-05-09 09:53:16.441 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:16.441 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.443 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.443 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.443 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.443 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.443 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.443 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.443 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.443 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.444 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.444 * UK100[M] Daily #1 | Reloading chart. | 2020-05-09 09:53:16.447 HD Request # 3 | Receiving historical Daily data for SIN20 starting at 2020-05-06 | 2020-05-09 09:53:16.452 HD Request # 3 | Writing historical Daily data to the file SIN20.dly | 2020-05-09 09:53:16.452 HD Request # 3 | Received 4 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for SIN20 | 2020-05-09 09:53:16.472 HD Request # 3 | Completion time: 0s | 2020-05-09 09:53:16.472 HD Request # 3 | Daily data download complete for SIN20. Unique request ID: 2 | 2020-05-09 09:53:16.472 Removing historical data download ID 2. | 2020-05-09 09:53:16.472 Triggering next historical data download in queue. | 2020-05-09 09:53:16.472 Mapping ZLN20 to ZLN20. Service code: cbot | 2020-05-09 09:53:16.472 HD Request # 5 | Downloading Historical Daily chart data for ZLN20. Starting date: 2020-05-06. Service: scdataallservices | 2020-05-09 09:53:16.475 HD Request # 5 | Requesting historical Daily data for ZLN20 starting at 2020-05-05 | 2020-05-09 09:53:16.475 Using Bid/Ask average for last trade price for GER30 | 2020-05-09 09:53:16.475 SC DTC Data with Market Depth | Starting real-time market data updates for: GER30. ID: 2 Service code: fxcm | 2020-05-09 09:53:16.475 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2020-05-09 09:53:16.475 SC DTC Data with Market Depth | Requesting security definition data for: GER30. ID: 2 | 2020-05-09 09:53:16.476 DTC Client socket (4) | Creating socket. | 2020-05-09 09:53:16.476 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:16.476 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.476 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.476 * Using Bid/Ask average for last trade price for FRA40 | 2020-05-09 09:53:16.476 SC DTC Data with Market Depth | Starting real-time market data updates for: FRA40. ID: 3 Service code: fxcm | 2020-05-09 09:53:16.476 SC DTC Data with Market Depth | Requesting security definition data for: FRA40. ID: 3 | 2020-05-09 09:53:16.476 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.476 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.476 * Using Bid/Ask average for last trade price for US30 | 2020-05-09 09:53:16.476 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 4 Service code: fxcm | 2020-05-09 09:53:16.476 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 4 | 2020-05-09 09:53:16.476 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.476 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.476 * Using Bid/Ask average for last trade price for NAS100 | 2020-05-09 09:53:16.477 SC DTC Data with Market Depth | Starting real-time market data updates for: NAS100. ID: 5 Service code: fxcm | 2020-05-09 09:53:16.477 SC DTC Data with Market Depth | Requesting security definition data for: NAS100. ID: 5 | 2020-05-09 09:53:16.477 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.477 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.477 * Using Bid/Ask average for last trade price for EURUSD | 2020-05-09 09:53:16.483 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm | 2020-05-09 09:53:16.483 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 6 | 2020-05-09 09:53:16.483 Using Bid/Ask average for last trade price for AUDUSD | 2020-05-09 09:53:16.489 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 7 Service code: fxcm | 2020-05-09 09:53:16.489 SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 7 | 2020-05-09 09:53:16.489 Using Bid/Ask average for last trade price for SPX500 | 2020-05-09 09:53:16.495 SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 8 Service code: fxcm | 2020-05-09 09:53:16.495 SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 8 | 2020-05-09 09:53:16.495 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.495 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.495 * Using Bid/Ask average for last trade price for GBPUSD | 2020-05-09 09:53:16.495 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 9 Service code: fxcm | 2020-05-09 09:53:16.495 SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 9 | 2020-05-09 09:53:16.496 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.513 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.514 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.515 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.515 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.516 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.516 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.516 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.516 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.517 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.517 * Using Bid/Ask average for last trade price for UK100 | 2020-05-09 09:53:16.518 SC DTC Data with Market Depth | Starting real-time market data updates for: UK100. ID: 10 Service code: fxcm | 2020-05-09 09:53:16.518 SC DTC Data with Market Depth | Requesting security definition data for: UK100. ID: 10 | 2020-05-09 09:53:16.518 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:16.518 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.518 * Using Bid/Ask average for last trade price for EURGBP | 2020-05-09 09:53:16.519 SC DTC Data with Market Depth | Starting real-time market data updates for: EURGBP. ID: 11 Service code: fxcm | 2020-05-09 09:53:16.519 SC DTC Data with Market Depth | Requesting security definition data for: EURGBP. ID: 11 | 2020-05-09 09:53:16.519 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:16.532 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:16.532 * HGN20 [CV] Daily #1 | Reloading chart. | 2020-05-09 09:53:16.534 HD Request # 4 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:16.684 HD Request # 4 | Sending historical data logon request message. | 2020-05-09 09:53:16.684 HD Request # 4 | Requesting historical Daily data starting at 2020-05-06. | 2020-05-09 09:53:16.794 HD Request # 4 | Decompressing data. | 2020-05-09 09:53:16.907 HD Request # 4 | Receiving historical Daily data for GER30 starting at 2020-05-06 | 2020-05-09 09:53:16.943 HD Request # 4 | Writing historical Daily data to the file GER30.dly | 2020-05-09 09:53:16.944 Socket (1) | CloseSocket call. | 2020-05-09 09:53:17.073 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:17.074 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:17.175 Socket (1) | Closed. | 2020-05-09 09:53:17.176 SC DTC Data with Market Depth | Connected to server. | 2020-05-09 09:53:17.552 SC DTC Data with Market Depth | Starting socket receive thread. | 2020-05-09 09:53:17.552 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2020-05-09 09:53:17.552 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:17.554 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:17.554 * Historical data download thread signaled to stop. | 2020-05-09 09:53:17.555 HD Request # 4 | Received 3 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for GER30 | 2020-05-09 09:53:17.555 HD Request # 4 | Completion time: 1s | 2020-05-09 09:53:17.555 HD Request # 4 | Daily data download complete for GER30. Unique request ID: 8 | 2020-05-09 09:53:17.555 Removing historical data download ID 8. | 2020-05-09 09:53:17.555 Triggering next historical data download in queue. | 2020-05-09 09:53:17.556 HD Request # 5 | Receiving historical Daily data for ZLN20 starting at 2020-05-06 | 2020-05-09 09:53:17.556 HD Request # 5 | Writing historical Daily data to the file ZLN20.dly | 2020-05-09 09:53:17.557 HD Request # 5 | Received 4 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for ZLN20 | 2020-05-09 09:53:17.569 HD Request # 5 | Completion time: 0s | 2020-05-09 09:53:17.569 HD Request # 5 | Daily data download complete for ZLN20. Unique request ID: 3 | 2020-05-09 09:53:17.569 Removing historical data download ID 3. | 2020-05-09 09:53:17.569 Triggering next historical data download in queue. | 2020-05-09 09:53:17.569 HD Request # 6 | Downloading Historical Daily chart data for FRA40. Starting date: 2020-05-06. Service: fxcm | 2020-05-09 09:53:17.572 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:17.572 Socket (1) | Creating socket. | 2020-05-09 09:53:17.572 Mapping CLM20 to CLM20. Service code: nymex | 2020-05-09 09:53:17.572 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:17.572 HD Request # 7 | Downloading Historical Daily chart data for CLM20. Starting date: 2020-05-06. Service: scdataallservices | 2020-05-09 09:53:17.575 HD Request # 7 | Requesting historical Daily data for CLM20 starting at 2020-05-05 | 2020-05-09 09:53:17.575 GER30[M] Daily #2 | Reloading chart. | 2020-05-09 09:53:17.577 SIN20 [CV] Daily #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-05-09 09:53:17.592 SIN20 [CV] Daily #2 | Reloading chart. | 2020-05-09 09:53:17.594 HD Request # 6 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:17.819 HD Request # 6 | Sending historical data logon request message. | 2020-05-09 09:53:17.819 HD Request # 6 | Requesting historical Daily data starting at 2020-05-06. | 2020-05-09 09:53:17.927 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:17.998 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:17.998 * SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:17.998 SC DTC Data with Market Depth | Sending logon request message. | 2020-05-09 09:53:17.998 ZLN20 [CV] Daily #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-05-09 09:53:17.998 ZLN20 [CV] Daily #3 | Reloading chart. | 2020-05-09 09:53:18.000 HD Request # 6 | Decompressing data. | 2020-05-09 09:53:18.042 HD Request # 6 | Receiving historical Daily data for FRA40 starting at 2020-05-06 | 2020-05-09 09:53:18.042 HD Request # 6 | Writing historical Daily data to the file FRA40.dly | 2020-05-09 09:53:18.043 Socket (1) | CloseSocket call. | 2020-05-09 09:53:18.101 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:18.101 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:18.209 Socket (1) | Closed. | 2020-05-09 09:53:18.209 Historical data download thread signaled to stop. | 2020-05-09 09:53:18.390 HD Request # 6 | Received 3 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for FRA40 | 2020-05-09 09:53:18.390 HD Request # 6 | Completion time: 0s | 2020-05-09 09:53:18.390 HD Request # 6 | Daily data download complete for FRA40. Unique request ID: 9 | 2020-05-09 09:53:18.390 Removing historical data download ID 9. | 2020-05-09 09:53:18.390 Triggering next historical data download in queue. | 2020-05-09 09:53:18.390 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:18.391 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:18.391 * HD Request # 8 | Downloading Historical Daily chart data for US30. Starting date: 2020-05-06. Service: fxcm | 2020-05-09 09:53:18.395 HD Request # 8 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:18.395 Socket (1) | Creating socket. | 2020-05-09 09:53:18.395 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:18.395 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:18.396 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:18.396 * Mapping HGN20 to HGN20. Service code: comex | 2020-05-09 09:53:18.396 SC DTC Delayed Exchange Data | Starting real-time market data updates for: HGN20 (HGN20). ID: 13 Service code: comex | 2020-05-09 09:53:18.396 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10044 | 2020-05-09 09:53:18.396 SC DTC Delayed Exchange Data | Requesting security definition data for: HGN20 (HGN20). ID: 13 | 2020-05-09 09:53:18.396 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:18.396 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:18.396 * DTC Client socket (3) | Creating socket. | 2020-05-09 09:53:18.397 DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2020-05-09 09:53:18.397 FRA40[M] Daily #3 | Reloading chart. | 2020-05-09 09:53:18.408 SIN20 [CV] Daily #2 | Reloading chart. | 2020-05-09 09:53:18.416 HD Request # 8 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:18.615 HD Request # 8 | Sending historical data logon request message. | 2020-05-09 09:53:18.615 HD Request # 8 | Requesting historical Daily data starting at 2020-05-06. | 2020-05-09 09:53:18.717 HD Request # 8 | Decompressing data. | 2020-05-09 09:53:18.819 HD Request # 8 | Receiving historical Daily data for US30 starting at 2020-05-06 | 2020-05-09 09:53:18.863 HD Request # 8 | Writing historical Daily data to the file US30.dly | 2020-05-09 09:53:18.863 Socket (1) | CloseSocket call. | 2020-05-09 09:53:18.999 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:18.999 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:19.108 Socket (1) | Closed. | 2020-05-09 09:53:19.108 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:19.211 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:19.211 * SC DTC Delayed Exchange Data | Connected to server. | 2020-05-09 09:53:19.211 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2020-05-09 09:53:19.211 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS | 2020-05-09 09:53:19.211 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:19.212 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:19.212 * HD Request # 7 | Receiving historical Daily data for CLM20 starting at 2020-05-06 | 2020-05-09 09:53:19.213 HD Request # 7 | Writing historical Daily data to the file CLM20.dly | 2020-05-09 09:53:19.213 HD Request # 7 | Received 4 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for CLM20 | 2020-05-09 09:53:19.247 HD Request # 7 | Completion time: 2s | 2020-05-09 09:53:19.247 HD Request # 7 | Daily data download complete for CLM20. Unique request ID: 4 | 2020-05-09 09:53:19.247 Removing historical data download ID 4. | 2020-05-09 09:53:19.247 Triggering next historical data download in queue. | 2020-05-09 09:53:19.247 Historical data download thread signaled to stop. | 2020-05-09 09:53:19.247 HD Request # 8 | Received 3 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for US30 | 2020-05-09 09:53:19.247 HD Request # 8 | Completion time: 1s | 2020-05-09 09:53:19.247 HD Request # 8 | Daily data download complete for US30. Unique request ID: 10 | 2020-05-09 09:53:19.247 Removing historical data download ID 10. | 2020-05-09 09:53:19.247 Triggering next historical data download in queue. | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Received logon response. | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Successfully connected. | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Trading is not supported. | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2020-05-09 09:53:19.247 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: FRA40 | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GER30 | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NAS100 | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UK100 | 2020-05-09 09:53:19.248 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2020-05-09 09:53:19.248 HD Request # 9 | Downloading Historical Daily chart data for CCN20. Starting date: 2020-05-06. Service: ice.us | 2020-05-09 09:53:19.251 HD Request # 9 | Requesting historical Daily data for CCN20 starting at 2020-05-05 | 2020-05-09 09:53:19.251 HD Request # 10 | Downloading Historical Daily chart data for NAS100. Starting date: 2020-05-06. Service: fxcm | 2020-05-09 09:53:19.255 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:19.255 Socket (2) | Creating socket. | 2020-05-09 09:53:19.255 Socket (2) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:19.255 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:19.255 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:19.255 * ZLN20 [CV] Daily #3 | Reloading chart. | 2020-05-09 09:53:19.258 HD Request # 10 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:19.478 HD Request # 10 | Sending historical data logon request message. | 2020-05-09 09:53:19.478 HD Request # 10 | Requesting historical Daily data starting at 2020-05-06. | 2020-05-09 09:53:19.590 HD Request # 10 | Decompressing data. | 2020-05-09 09:53:19.711 HD Request # 10 | Receiving historical Daily data for NAS100 starting at 2020-05-06 | 2020-05-09 09:53:19.711 HD Request # 10 | Writing historical Daily data to the file NAS100.dly | 2020-05-09 09:53:19.712 Socket (2) | CloseSocket call. | 2020-05-09 09:53:19.756 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:19.756 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:19.864 Socket (2) | Closed. | 2020-05-09 09:53:19.864 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:20.004 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.004 * Historical data download thread signaled to stop. | 2020-05-09 09:53:20.004 HD Request # 10 | Received 3 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for NAS100 | 2020-05-09 09:53:20.004 HD Request # 10 | Completion time: 0s | 2020-05-09 09:53:20.004 HD Request # 10 | Daily data download complete for NAS100. Unique request ID: 11 | 2020-05-09 09:53:20.004 Removing historical data download ID 11. | 2020-05-09 09:53:20.004 Triggering next historical data download in queue. | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol FRA40 | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol GER30 | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol NAS100 | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol UK100 | 2020-05-09 09:53:20.004 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2020-05-09 09:53:20.004 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:20.004 SC DTC Delayed Exchange Data | Sending logon request message. | 2020-05-09 09:53:20.004 HD Request # 11 | Downloading Historical Daily chart data for SPX500. Starting date: 2020-05-06. Service: fxcm | 2020-05-09 09:53:20.007 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:20.008 Socket (2) | Creating socket. | 2020-05-09 09:53:20.008 Socket (2) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:20.008 US30[M] Daily #4 | Reloading chart. | 2020-05-09 09:53:20.011 NAS100[M] Daily #5 | Reloading chart. | 2020-05-09 09:53:20.018 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:20.030 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.030 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:20.064 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.064 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:20.064 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.064 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:20.064 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.064 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:20.065 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.065 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:20.065 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.065 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:20.065 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:20.065 * CLM20 [CV] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-05-09 09:53:20.081 CLM20 [CV] Daily #4 | Reloading chart. | 2020-05-09 09:53:20.085 HD Request # 11 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:20.234 HD Request # 11 | Sending historical data logon request message. | 2020-05-09 09:53:20.234 HD Request # 11 | Requesting historical Daily data starting at 2020-05-06. | 2020-05-09 09:53:20.339 HD Request # 11 | Decompressing data. | 2020-05-09 09:53:20.441 HD Request # 11 | Receiving historical Daily data for SPX500 starting at 2020-05-06 | 2020-05-09 09:53:20.486 HD Request # 11 | Writing historical Daily data to the file SPX500.dly | 2020-05-09 09:53:20.486 Socket (2) | CloseSocket call. | 2020-05-09 09:53:20.603 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:20.603 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:20.710 Socket (2) | Closed. | 2020-05-09 09:53:20.710 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:21.793 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:21.793 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:21.794 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:21.794 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:21.795 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:21.795 * Historical data download thread signaled to stop. | 2020-05-09 09:53:21.796 HD Request # 11 | Received 3 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for SPX500 | 2020-05-09 09:53:21.796 HD Request # 11 | Completion time: 0s | 2020-05-09 09:53:21.796 HD Request # 11 | Daily data download complete for SPX500. Unique request ID: 12 | 2020-05-09 09:53:21.796 Removing historical data download ID 12. | 2020-05-09 09:53:21.796 Triggering next historical data download in queue. | 2020-05-09 09:53:21.796 HD Request # 9 | Receiving historical Daily data for CCN20 starting at 2020-05-06 | 2020-05-09 09:53:21.796 HD Request # 9 | Writing historical Daily data to the file CCN20.dly | 2020-05-09 09:53:21.796 HD Request # 9 | Received 4 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for CCN20 | 2020-05-09 09:53:21.803 HD Request # 9 | Completion time: 2s | 2020-05-09 09:53:21.803 HD Request # 9 | Daily data download complete for CCN20. Unique request ID: 5 | 2020-05-09 09:53:21.803 Removing historical data download ID 5. | 2020-05-09 09:53:21.803 Triggering next historical data download in queue. | 2020-05-09 09:53:21.803 SC DTC Delayed Exchange Data | Received logon response. | 2020-05-09 09:53:21.803 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2020-05-09 09:53:21.803 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2020-05-09 09:53:21.803 SC DTC Delayed Exchange Data | Successfully connected. | 2020-05-09 09:53:21.804 SC DTC Delayed Exchange Data | Trading is not supported. | 2020-05-09 09:53:21.804 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: HGN20 -> HGN20 | 2020-05-09 09:53:21.804 Delaying start of download for GER30 | 2020-05-09 09:53:21.804 Mapping GCM20 to GCM20. Service code: comex | 2020-05-09 09:53:21.804 HD Request # 12 | Downloading Historical Daily chart data for GCM20. Starting date: 2020-05-06. Service: scdataallservices | 2020-05-09 09:53:21.807 HD Request # 12 | Requesting historical Daily data for GCM20 starting at 2020-05-05 | 2020-05-09 09:53:21.807 Mapping SIN20 to SIN20. Service code: comex | 2020-05-09 09:53:21.807 SC DTC Delayed Exchange Data | Starting real-time market data updates for: SIN20 (SIN20). ID: 16 Service code: comex | 2020-05-09 09:53:21.807 SC DTC Delayed Exchange Data | Requesting security definition data for: SIN20 (SIN20). ID: 16 | 2020-05-09 09:53:21.807 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:21.808 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:21.808 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:21.808 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:21.808 * CCN20 [CV] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-05-09 09:53:21.809 CCN20 [CV] Daily #5 | Reloading chart. | 2020-05-09 09:53:21.811 SC DTC Delayed Exchange Data | Received security definition for symbol HGN20 | 2020-05-09 09:53:22.061 SC DTC Delayed Exchange Data | Received security definition for symbol SIN20 | 2020-05-09 09:53:22.061 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:22.061 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:22.061 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:22.062 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:22.062 * SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZLN20 (ZLN20). ID: 1 Service code: cbot | 2020-05-09 09:53:22.068 SC DTC Delayed Exchange Data | Requesting security definition data for: ZLN20 (ZLN20). ID: 1 | 2020-05-09 09:53:22.068 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:22.068 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:22.068 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:22.069 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:22.069 * SPX500[M] Daily #6 | Reloading chart. | 2020-05-09 09:53:22.072 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:22.095 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:22.095 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:22.096 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:22.096 * CLM20 [CV] Daily #4 | Reloading chart. | 2020-05-09 09:53:22.098 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:24.309 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:24.309 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:24.311 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:24.311 * HD Request # 12 | Receiving historical Daily data for GCM20 starting at 2020-05-06 | 2020-05-09 09:53:24.311 HD Request # 12 | Writing historical Daily data to the file GCM20.dly | 2020-05-09 09:53:24.311 HD Request # 12 | Received 4 records from 2020-05-06 00:00:00 to 2020-05-08 00:00:00 (3.0 days) and wrote 3 records for GCM20 | 2020-05-09 09:53:24.340 HD Request # 12 | Completion time: 3s | 2020-05-09 09:53:24.340 HD Request # 12 | Daily data download complete for GCM20. Unique request ID: 6 | 2020-05-09 09:53:24.340 Removing historical data download ID 6. | 2020-05-09 09:53:24.340 Triggering next historical data download in queue. | 2020-05-09 09:53:24.340 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:24.341 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:24.341 * SC DTC Delayed Exchange Data | Received security definition for symbol ZLN20 | 2020-05-09 09:53:24.341 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:24.341 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:24.341 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:24.353 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:24.353 * CCN20 [CV] Daily #5 | Reloading chart. | 2020-05-09 09:53:24.355 GCM20 [CV] Daily #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-05-09 09:53:24.935 GCM20 [CV] Daily #7 | Reloading chart. | 2020-05-09 09:53:24.937 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:25.345 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:25.345 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:53:25.346 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:25.346 * SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLM20 (CLM20). ID: 12 Service code: nymex | 2020-05-09 09:53:25.346 SC DTC Delayed Exchange Data | Requesting security definition data for: CLM20 (CLM20). ID: 12 | 2020-05-09 09:53:25.346 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:25.346 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:25.346 * HD Request # 13 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2020-05-09 09:53:25.356 HD Request # 13 | Download start date-time: 2020-05-08 20:59:59.000 | 2020-05-09 09:53:25.357 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:25.357 Socket (1) | Creating socket. | 2020-05-09 09:53:25.357 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:25.357 SC Data - All Services | Starting real-time market data updates for: CCN20. ID: 14 Service code: ice.us | 2020-05-09 09:53:25.358 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: CCN20 | 2020-05-09 09:53:25.358 SC Data - All Services | Requesting security definition data for: CCN20. ID: 14 | 2020-05-09 09:53:25.358 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:25.358 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:25.358 * GCM20 [CV] Daily #7 | Reloading chart. | 2020-05-09 09:53:25.432 HD Request # 13 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:25.610 HD Request # 13 | Sending historical data logon request message. | 2020-05-09 09:53:25.610 HD Request # 13 | Requesting Intraday data. Start date-time: 2020-05-08 20:59:59. Record interval: 1. Symbol: GER30 | 2020-05-09 09:53:25.726 HD Request # 13 | Decompressing data. | 2020-05-09 09:53:25.841 HD Request # 13 | Receiving Intraday data for GER30 starting at 2020-05-08 20:59:59 | 2020-05-09 09:53:25.841 Socket (1) | CloseSocket call. | 2020-05-09 09:53:25.842 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:25.842 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:25.957 Socket (1) | Closed. | 2020-05-09 09:53:25.957 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:26.221 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:26.221 * Historical data download thread signaled to stop. | 2020-05-09 09:53:26.222 HD Request # 13 | Timestamp of first Intraday data file record written: 2020-05-08 20:59:59 | 2020-05-09 09:53:26.222 HD Request # 13 | Received 1 record from 2020-05-08 20:59:59.000 to 2020-05-08 20:59:59.000 (0.0 seconds) and wrote 1 record for GER30 | 2020-05-09 09:53:26.222 HD Request # 13 | Completion time: 1s | 2020-05-09 09:53:26.222 HD Request # 13 | Intraday data download complete for GER30. Unique request ID: 13 | 2020-05-09 09:53:26.223 Removing historical data download ID 13. | 2020-05-09 09:53:26.223 Real-time Intraday chart data file updates started for GER30 | 2020-05-09 09:53:26.223 Opened cached Intraday file: C:\SierraChart\Data\GER30.scid. Thread ID: 8476 | 2020-05-09 09:53:26.223 Intraday chart data file opened for GER30 | 2020-05-09 09:53:26.223 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:26.223 Triggering next historical data download in queue. | 2020-05-09 09:53:26.223 SC DTC Delayed Exchange Data | Received security definition for symbol CLM20 | 2020-05-09 09:53:26.223 HD Request # 14 | Downloading Intraday chart data for NAS100 to the file NAS100.scid. Service: fxcm | 2020-05-09 09:53:26.223 HD Request # 14 | Download start date-time: 2020-05-08 21:14:59.000 | 2020-05-09 09:53:26.224 HD Request # 14 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:26.224 Socket (1) | Creating socket. | 2020-05-09 09:53:26.224 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:26.224 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:26.225 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:26.225 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:26.233 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:26.233 * SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCM20 (GCM20). ID: 15 Service code: comex | 2020-05-09 09:53:26.234 SC DTC Delayed Exchange Data | Requesting security definition data for: GCM20 (GCM20). ID: 15 | 2020-05-09 09:53:26.234 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:26.234 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:26.234 * SC DTC Delayed Exchange Data | Received security definition for symbol GCM20 | 2020-05-09 09:53:26.363 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:53:26.432 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:26.432 * HD Request # 14 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:26.442 HD Request # 14 | Sending historical data logon request message. | 2020-05-09 09:53:26.442 HD Request # 14 | Requesting Intraday data. Start date-time: 2020-05-08 21:14:59. Record interval: 1. Symbol: NAS100 | 2020-05-09 09:53:26.544 HD Request # 14 | Decompressing data. | 2020-05-09 09:53:26.646 HD Request # 14 | Receiving Intraday data for NAS100 starting at 2020-05-08 21:14:59 | 2020-05-09 09:53:26.647 Socket (1) | CloseSocket call. | 2020-05-09 09:53:26.649 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:26.650 Historical data download thread signaled to stop. | 2020-05-09 09:53:26.650 HD Request # 14 | Timestamp of first Intraday data file record written: 2020-05-08 21:14:59 | 2020-05-09 09:53:26.650 HD Request # 14 | Received 1 record from 2020-05-08 21:14:59.000 to 2020-05-08 21:14:59.000 (0.0 seconds) and wrote 1 record for NAS100 | 2020-05-09 09:53:26.651 HD Request # 14 | Completion time: 0s | 2020-05-09 09:53:26.652 HD Request # 14 | Intraday data download complete for NAS100. Unique request ID: 14 | 2020-05-09 09:53:26.652 Removing historical data download ID 14. | 2020-05-09 09:53:26.652 Real-time Intraday chart data file updates started for NAS100 | 2020-05-09 09:53:26.652 Opened cached Intraday file: C:\SierraChart\Data\NAS100.scid. Thread ID: 8476 | 2020-05-09 09:53:26.653 Intraday chart data file opened for NAS100 | 2020-05-09 09:53:26.653 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:26.653 Triggering next historical data download in queue. | 2020-05-09 09:53:26.653 HD Request # 15 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2020-05-09 09:53:26.653 HD Request # 15 | Download start date-time: 2020-05-08 21:14:58.000 | 2020-05-09 09:53:26.655 HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:26.655 Socket (2) | Creating socket. | 2020-05-09 09:53:26.655 Socket (2) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:26.655 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:26.751 Socket (1) | Closed. | 2020-05-09 09:53:26.751 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:26.771 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:26.771 * HD Request # 15 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:26.894 HD Request # 15 | Sending historical data logon request message. | 2020-05-09 09:53:26.894 HD Request # 15 | Requesting Intraday data. Start date-time: 2020-05-08 21:14:58. Record interval: 1. Symbol: US30 | 2020-05-09 09:53:27.011 HD Request # 15 | Decompressing data. | 2020-05-09 09:53:27.128 HD Request # 15 | Receiving Intraday data for US30 starting at 2020-05-08 21:14:58 | 2020-05-09 09:53:27.128 Socket (2) | CloseSocket call. | 2020-05-09 09:53:27.131 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:27.131 Historical data download thread signaled to stop. | 2020-05-09 09:53:27.131 HD Request # 15 | Timestamp of first Intraday data file record written: 2020-05-08 21:14:58 | 2020-05-09 09:53:27.132 HD Request # 15 | Received 1 record from 2020-05-08 21:14:58.000 to 2020-05-08 21:14:58.000 (0.0 seconds) and wrote 1 record for US30 | 2020-05-09 09:53:27.132 HD Request # 15 | Completion time: 0s | 2020-05-09 09:53:27.134 HD Request # 15 | Intraday data download complete for US30. Unique request ID: 15 | 2020-05-09 09:53:27.134 Removing historical data download ID 15. | 2020-05-09 09:53:27.134 Real-time Intraday chart data file updates started for US30 | 2020-05-09 09:53:27.134 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 8476 | 2020-05-09 09:53:27.135 Intraday chart data file opened for US30 | 2020-05-09 09:53:27.135 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:27.135 Triggering next historical data download in queue. | 2020-05-09 09:53:27.135 HD Request # 16 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2020-05-09 09:53:27.135 HD Request # 16 | Download start date-time: 2020-05-08 21:14:59.000 | 2020-05-09 09:53:27.137 HD Request # 16 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:27.137 Socket (1) | Creating socket. | 2020-05-09 09:53:27.137 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:27.137 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:27.253 Socket (2) | Closed. | 2020-05-09 09:53:27.253 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:27.276 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:27.276 * HD Request # 16 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:27.361 HD Request # 16 | Sending historical data logon request message. | 2020-05-09 09:53:27.361 HD Request # 16 | Requesting Intraday data. Start date-time: 2020-05-08 21:14:59. Record interval: 1. Symbol: SPX500 | 2020-05-09 09:53:27.463 HD Request # 16 | Decompressing data. | 2020-05-09 09:53:27.567 HD Request # 16 | Receiving Intraday data for SPX500 starting at 2020-05-08 21:14:59 | 2020-05-09 09:53:27.567 Socket (1) | CloseSocket call. | 2020-05-09 09:53:27.570 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:27.570 Historical data download thread signaled to stop. | 2020-05-09 09:53:27.570 HD Request # 16 | Timestamp of first Intraday data file record written: 2020-05-08 21:14:59 | 2020-05-09 09:53:27.571 HD Request # 16 | Received 1 record from 2020-05-08 21:14:59.000 to 2020-05-08 21:14:59.000 (0.0 seconds) and wrote 1 record for SPX500 | 2020-05-09 09:53:27.571 HD Request # 16 | Completion time: 0s | 2020-05-09 09:53:27.571 HD Request # 16 | Intraday data download complete for SPX500. Unique request ID: 16 | 2020-05-09 09:53:27.571 Removing historical data download ID 16. | 2020-05-09 09:53:27.571 Real-time Intraday chart data file updates started for SPX500 | 2020-05-09 09:53:27.571 Opened cached Intraday file: C:\SierraChart\Data\SPX500.scid. Thread ID: 8476 | 2020-05-09 09:53:27.572 Intraday chart data file opened for SPX500 | 2020-05-09 09:53:27.572 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:27.572 Triggering next historical data download in queue. | 2020-05-09 09:53:27.572 HD Request # 17 | Downloading Intraday chart data for FRA40 to the file FRA40.scid. Service: fxcm | 2020-05-09 09:53:27.572 HD Request # 17 | Download start date-time: 2020-05-08 20:59:59.000 | 2020-05-09 09:53:27.572 HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:27.572 Socket (2) | Creating socket. | 2020-05-09 09:53:27.572 Socket (2) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:27.572 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:27.673 Socket (1) | Closed. | 2020-05-09 09:53:27.673 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:27.779 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:27.779 * HD Request # 17 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:27.812 HD Request # 17 | Sending historical data logon request message. | 2020-05-09 09:53:27.812 HD Request # 17 | Requesting Intraday data. Start date-time: 2020-05-08 20:59:59. Record interval: 1. Symbol: FRA40 | 2020-05-09 09:53:27.929 HD Request # 17 | Decompressing data. | 2020-05-09 09:53:28.050 HD Request # 17 | Receiving Intraday data for FRA40 starting at 2020-05-08 20:59:59 | 2020-05-09 09:53:28.050 Socket (2) | CloseSocket call. | 2020-05-09 09:53:28.053 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:28.054 Historical data download thread signaled to stop. | 2020-05-09 09:53:28.054 HD Request # 17 | Timestamp of first Intraday data file record written: 2020-05-08 20:59:59 | 2020-05-09 09:53:28.054 HD Request # 17 | Received 1 record from 2020-05-08 20:59:59.000 to 2020-05-08 20:59:59.000 (0.0 seconds) and wrote 1 record for FRA40 | 2020-05-09 09:53:28.055 HD Request # 17 | Completion time: 1s | 2020-05-09 09:53:28.056 HD Request # 17 | Intraday data download complete for FRA40. Unique request ID: 17 | 2020-05-09 09:53:28.056 Removing historical data download ID 17. | 2020-05-09 09:53:28.056 Real-time Intraday chart data file updates started for FRA40 | 2020-05-09 09:53:28.056 Opened cached Intraday file: C:\SierraChart\Data\FRA40.scid. Thread ID: 8476 | 2020-05-09 09:53:28.057 Intraday chart data file opened for FRA40 | 2020-05-09 09:53:28.057 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:28.057 Triggering next historical data download in queue. | 2020-05-09 09:53:28.057 HD Request # 18 | Downloading Intraday chart data for UK100 to the file UK100.scid. Service: fxcm | 2020-05-09 09:53:28.057 HD Request # 18 | Download start date-time: 2020-05-07 20:59:59.000 | 2020-05-09 09:53:28.059 HD Request # 18 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:28.059 Socket (1) | Creating socket. | 2020-05-09 09:53:28.059 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:28.059 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:28.170 Socket (2) | Closed. | 2020-05-09 09:53:28.170 HD Request # 18 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:28.275 HD Request # 18 | Sending historical data logon request message. | 2020-05-09 09:53:28.275 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:28.364 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:28.364 * HD Request # 18 | Requesting Intraday data. Start date-time: 2020-05-07 20:59:59. Record interval: 1. Symbol: UK100 | 2020-05-09 09:53:28.377 HD Request # 18 | Decompressing data. | 2020-05-09 09:53:28.480 HD Request # 18 | Receiving Intraday data for UK100 starting at 2020-05-07 20:59:59 | 2020-05-09 09:53:28.480 Socket (1) | CloseSocket call. | 2020-05-09 09:53:28.484 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:28.484 Historical data download thread signaled to stop. | 2020-05-09 09:53:28.484 HD Request # 18 | Timestamp of first Intraday data file record written: 2020-05-07 20:59:59 | 2020-05-09 09:53:28.485 HD Request # 18 | Received 1 record from 2020-05-07 20:59:59.000 to 2020-05-07 20:59:59.000 (0.0 seconds) and wrote 1 record for UK100 | 2020-05-09 09:53:28.486 HD Request # 18 | Completion time: 0s | 2020-05-09 09:53:28.488 HD Request # 18 | Intraday data download complete for UK100. Unique request ID: 18 | 2020-05-09 09:53:28.488 Removing historical data download ID 18. | 2020-05-09 09:53:28.488 Real-time Intraday chart data file updates started for UK100 | 2020-05-09 09:53:28.488 Opened cached Intraday file: C:\SierraChart\Data\UK100.scid. Thread ID: 8476 | 2020-05-09 09:53:28.489 Intraday chart data file opened for UK100 | 2020-05-09 09:53:28.489 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:28.489 Triggering next historical data download in queue. | 2020-05-09 09:53:28.489 HD Request # 19 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2020-05-09 09:53:28.489 HD Request # 19 | Download start date-time: 2020-05-08 21:59:01.000 | 2020-05-09 09:53:28.490 HD Request # 19 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:28.490 Socket (2) | Creating socket. | 2020-05-09 09:53:28.490 Socket (2) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:28.490 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:28.591 Socket (1) | Closed. | 2020-05-09 09:53:28.591 HD Request # 19 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:28.747 HD Request # 19 | Sending historical data logon request message. | 2020-05-09 09:53:28.748 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:53:28.867 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:53:28.867 * HD Request # 19 | Requesting Intraday data. Start date-time: 2020-05-08 21:59:01. Record interval: 1. Symbol: EURUSD | 2020-05-09 09:53:28.880 HD Request # 19 | Decompressing data. | 2020-05-09 09:53:29.006 HD Request # 19 | Receiving Intraday data for EURUSD starting at 2020-05-08 21:59:01 | 2020-05-09 09:53:29.006 Socket (2) | CloseSocket call. | 2020-05-09 09:53:29.009 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:29.009 Historical data download thread signaled to stop. | 2020-05-09 09:53:29.009 HD Request # 19 | Timestamp of first Intraday data file record written: 2020-05-08 21:59:01 | 2020-05-09 09:53:29.010 HD Request # 19 | Received 1 record from 2020-05-08 21:59:01.000 to 2020-05-08 21:59:01.000 (0.0 seconds) and wrote 1 record for EURUSD | 2020-05-09 09:53:29.010 HD Request # 19 | Completion time: 1s | 2020-05-09 09:53:29.010 HD Request # 19 | Intraday data download complete for EURUSD. Unique request ID: 19 | 2020-05-09 09:53:29.010 Removing historical data download ID 19. | 2020-05-09 09:53:29.010 Real-time Intraday chart data file updates started for EURUSD | 2020-05-09 09:53:29.010 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 8476 | 2020-05-09 09:53:29.011 Intraday chart data file opened for EURUSD | 2020-05-09 09:53:29.011 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:29.011 Triggering next historical data download in queue. | 2020-05-09 09:53:29.011 HD Request # 20 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2020-05-09 09:53:29.011 HD Request # 20 | Download start date-time: 2020-05-08 21:58:44.000 | 2020-05-09 09:53:29.011 HD Request # 20 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:29.011 Socket (1) | Creating socket. | 2020-05-09 09:53:29.011 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:29.012 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:29.133 Socket (2) | Closed. | 2020-05-09 09:53:29.134 HD Request # 20 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:29.227 HD Request # 20 | Sending historical data logon request message. | 2020-05-09 09:53:29.227 HD Request # 20 | Requesting Intraday data. Start date-time: 2020-05-08 21:58:44. Record interval: 1. Symbol: AUDUSD | 2020-05-09 09:53:29.329 HD Request # 20 | Decompressing data. | 2020-05-09 09:53:29.432 HD Request # 20 | Receiving Intraday data for AUDUSD starting at 2020-05-08 21:58:44 | 2020-05-09 09:53:29.432 Socket (1) | CloseSocket call. | 2020-05-09 09:53:29.434 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:29.434 Historical data download thread signaled to stop. | 2020-05-09 09:53:29.434 HD Request # 20 | Timestamp of first Intraday data file record written: 2020-05-08 21:58:44 | 2020-05-09 09:53:29.435 HD Request # 20 | Received 1 record from 2020-05-08 21:58:44.000 to 2020-05-08 21:58:44.000 (0.0 seconds) and wrote 1 record for AUDUSD | 2020-05-09 09:53:29.435 HD Request # 20 | Completion time: 0s | 2020-05-09 09:53:29.437 HD Request # 20 | Intraday data download complete for AUDUSD. Unique request ID: 20 | 2020-05-09 09:53:29.437 Removing historical data download ID 20. | 2020-05-09 09:53:29.437 Real-time Intraday chart data file updates started for AUDUSD | 2020-05-09 09:53:29.437 Opened cached Intraday file: C:\SierraChart\Data\AUDUSD.scid. Thread ID: 8476 | 2020-05-09 09:53:29.438 Intraday chart data file opened for AUDUSD | 2020-05-09 09:53:29.438 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:29.438 Triggering next historical data download in queue. | 2020-05-09 09:53:29.438 HD Request # 21 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2020-05-09 09:53:29.438 HD Request # 21 | Download start date-time: 2020-05-08 21:59:02.000 | 2020-05-09 09:53:29.440 HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2020-05-09 09:53:29.440 Socket (2) | Creating socket. | 2020-05-09 09:53:29.440 Socket (2) | Connecting to IP: 192.81.56.146. | 2020-05-09 09:53:29.441 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:29.537 Socket (1) | Closed. | 2020-05-09 09:53:29.537 HD Request # 21 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:29.682 HD Request # 21 | Sending historical data logon request message. | 2020-05-09 09:53:29.682 HD Request # 21 | Requesting Intraday data. Start date-time: 2020-05-08 21:59:02. Record interval: 1. Symbol: GBPUSD | 2020-05-09 09:53:29.799 HD Request # 21 | Decompressing data. | 2020-05-09 09:53:29.916 HD Request # 21 | Receiving Intraday data for GBPUSD starting at 2020-05-08 21:59:02 | 2020-05-09 09:53:29.916 Socket (2) | CloseSocket call. | 2020-05-09 09:53:29.920 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:29.920 Historical data download thread signaled to stop. | 2020-05-09 09:53:29.920 HD Request # 21 | Timestamp of first Intraday data file record written: 2020-05-08 21:59:02 | 2020-05-09 09:53:29.921 HD Request # 21 | Received 1 record from 2020-05-08 21:59:02.000 to 2020-05-08 21:59:02.000 (0.0 seconds) and wrote 1 record for GBPUSD | 2020-05-09 09:53:29.921 HD Request # 21 | Completion time: 0s | 2020-05-09 09:53:29.923 HD Request # 21 | Intraday data download complete for GBPUSD. Unique request ID: 21 | 2020-05-09 09:53:29.923 Removing historical data download ID 21. | 2020-05-09 09:53:29.923 Real-time Intraday chart data file updates started for GBPUSD | 2020-05-09 09:53:29.923 Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid. Thread ID: 8476 | 2020-05-09 09:53:29.925 Intraday chart data file opened for GBPUSD | 2020-05-09 09:53:29.925 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:29.925 Triggering next historical data download in queue. | 2020-05-09 09:53:29.925 HD Request # 22 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2020-05-09 09:53:29.925 HD Request # 22 | Download start date-time: 2020-05-08 21:59:00.000 | 2020-05-09 09:53:29.927 HD Request # 22 | Using server: ds3.sierracharts.com port 10150 | 2020-05-09 09:53:29.927 Socket (1) | Creating socket. | 2020-05-09 09:53:29.927 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-05-09 09:53:29.928 Socket (2) | Socket gracefully closed by remote side. | 2020-05-09 09:53:30.037 Socket (2) | Closed. | 2020-05-09 09:53:30.037 HD Request # 22 | Setting DTC encoding to Binary VLS | 2020-05-09 09:53:30.144 HD Request # 22 | Sending historical data logon request message. | 2020-05-09 09:53:30.144 HD Request # 22 | Requesting Intraday data. Start date-time: 2020-05-08 21:59:00. Record interval: 1. Symbol: EURGBP | 2020-05-09 09:53:30.245 HD Request # 22 | Decompressing data. | 2020-05-09 09:53:30.347 HD Request # 22 | Receiving Intraday data for EURGBP starting at 2020-05-08 21:59:00 | 2020-05-09 09:53:30.348 Socket (1) | CloseSocket call. | 2020-05-09 09:53:30.349 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-09 09:53:30.349 Historical data download thread signaled to stop. | 2020-05-09 09:53:30.349 HD Request # 22 | Timestamp of first Intraday data file record written: 2020-05-08 21:59:00 | 2020-05-09 09:53:30.349 HD Request # 22 | Received 1 record from 2020-05-08 21:59:00.000 to 2020-05-08 21:59:00.000 (0.0 seconds) and wrote 1 record for EURGBP | 2020-05-09 09:53:30.349 HD Request # 22 | Completion time: 0s | 2020-05-09 09:53:30.350 HD Request # 22 | Intraday data download complete for EURGBP. Unique request ID: 22 | 2020-05-09 09:53:30.350 Removing historical data download ID 22. | 2020-05-09 09:53:30.350 Real-time Intraday chart data file updates started for EURGBP | 2020-05-09 09:53:30.350 Opened cached Intraday file: C:\SierraChart\Data\EURGBP.scid. Thread ID: 8476 | 2020-05-09 09:53:30.350 Intraday chart data file opened for EURGBP | 2020-05-09 09:53:30.350 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2020-05-09 09:53:30.350 Triggering next historical data download in queue. | 2020-05-09 09:53:30.350 Socket (1) | Socket gracefully closed by remote side. | 2020-05-09 09:53:30.451 Socket (1) | Closed. | 2020-05-09 09:53:30.451 Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:56:30.718 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.718 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:56:30.719 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.719 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:56:30.720 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.720 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:56:30.721 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.721 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:56:30.722 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.722 * Warning: The Custom DLL study "ACTS.scsf_catclub" has just caused a CPU exception. | 2020-05-09 09:56:30.723 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.723 * Saved Chartbook: ACTS.cht. Time: 0.0135 seconds. | 2020-05-09 09:56:30.731 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:56:30.732 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.732 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:56:30.733 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.733 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:56:30.734 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.735 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:56:30.735 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.735 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:56:30.736 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.736 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_eod" has just caused a CPU exception. | 2020-05-09 09:56:30.737 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.737 * Saved Chartbook: NewWizardEOD.cht. Time: 0.0085 seconds. | 2020-05-09 09:56:30.740 Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:56:30.741 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.741 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:56:30.742 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.742 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:56:30.742 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.742 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:56:30.742 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.742 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:56:30.743 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.743 * Warning: The Custom DLL study "NewWizard.scsf_new_wizard_intraday" has just caused a CPU exception. | 2020-05-09 09:56:30.743 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2020-05-09 09:56:30.743 * Saved Chartbook: NewWizardIntraday.cht. Time: 0.0050 seconds. | 2020-05-09 09:56:30.746 Saved Chartbook: ProjectX.cht. Time: 0.0037 seconds. | 2020-05-09 09:56:30.750 |
[2020-05-09 09:46:21] |
We only provided a new ProjectX.dll file. We only had the source code for that from your developer. We will contact your developer about the other files.
[2020-05-09 20:22:38] |
User92899 - Posts: 73 |
Oh - I see. Sorry - I did email Onn but had no reply yet. I realise why Proj X was the only one with signals now! No worries, as and when. Hope you are all staying safe and well over there! |
