Date/Time: Thu, 16 May 2024 20:36:20 +0000
Chart Calculator
View Count: 517
[2020-05-02 11:48:02] |
User20615 - Posts: 17 |
Hello, There was a change in behavior of Tools/Chart Calculator. Currency Value label is now multiplied by the Trade Window Order Quantity. Is it possible to add setting to disable this in future releases? It is more useful for me to show Currency Value not multiplied by number of contracts. Thank you, regards Jan |
[2020-05-05 13:06:31] |
It is disabled when you disable Trade >>Chart Trade Mode On for the chart.
[2020-05-05 14:08:16] |
Yes, I know, but I need Trade>>Chart Trade Mode On enabled... Please, is it possible to add checkbox to disable this behavior into Chart Calculator config? Thank you very much. |
