Date/Time: Fri, 26 Apr 2024 17:52:18 +0000
Limit of 200 queries per day for historical data
View Count: 1339
[2014-01-18 13:29:55] |
michelh - Posts: 159 |
Hi, I am trialling your service and like your software so far I am a top down stock position trader and I like to export my list from my screener into your watchlist feature. my problem is that when I close a position and I am ready to open a new one, I need to scan ~300 charts with a max of 500. but the downloads fail after 200 charts it says HD Request # 14 - Error downloading historical Daily data for ????. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2014-01-18 08:22:57 I was looking to purchase package 3 and use your historical stock feed. Is the limit of 200 queries for the trial only? If I buy package 3 will this limitation be removed? please note that I do not look at 300-500/charts a day. I do this when I close a position and have some money to put to work. So the need for this level of usage would not be a daily event. please tell me if there is a way around this limitation on the historical feed. I am not a day trader and have no need for real time data. However, I will occasionally look at an intra-day chart prior to taking a position. thanks for clarifying. |
[2014-01-18 14:59:03] |
Sierra Chart - Max - Posts: 5596 |
Regarding daily limitations on Historical Data Requests: The trial is limited to 200 requests/day. Package 3 is limited to 700 requests/day. Package 5 is limited to 1500 requests/day. Sierra Chart Support |
[2014-01-18 19:04:27] |
So you should be fine on package 3. If you enabled this data feed on your account: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php You will also have access to historical Daily stock data and there is no download limitations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-19 13:00:04] |
thank you! If I query the same symbol twice in a day does this count as two queries? e.g. let's say I need to view my watchlist twice for some reason. if it does, I might be safer with package 5 even though I don't need the additional features. |
[2014-01-19 15:00:35] |
also, if i download daily data for a symbol but then went to look at an intraday chart...is this a new data request? thanks for clarifying. |
[2014-01-19 19:00:36] |
If I query the same symbol twice in a day does this count as two queries? No, unless you were to restart Sierra Chart between viewing a chart.also, if i download daily data for a symbol but then went to look at an intraday chart...is this a new data request? Yes it is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-19 19:01:02
