Date/Time: Sat, 18 May 2024 21:05:57 +0000
[User Discussion] - One Period Based on Bar Count for the Orderbook
View Count: 474
[2020-05-01 18:28:24] |
Dany3003 - Posts: 6 |
Hi I have a question. In the volume profile there is a setting called One Period Based on Bar Count to make the volume profile easier to read. Is it possible to make this setting for the order book? You always have a profile (Recent,Current BID/ASK/Volume) that starts at zero and every time you press the clear button the profile is back to zero, I think the flow would be much easier to read with this function from the volume profile because you don't always start at zero. And with the One Period Based on Bar Count function, you have many options because you can also use the non-time-based timeframes to clear the profile. You can choose than a small timeframe for the recent BID / ASK and a longer for Current Traded BID / ASK/Volume and you never have the zero cut in the book again. Therefore my question is that possible? thanks in advance |
