Date/Time: Sat, 18 May 2024 14:09:44 +0000
VER 2095-2098 : QUOTEBOARD
View Count: 506
[2020-05-01 13:13:16] |
NRGTrader - Posts: 351 |
I have been using a quoteboard with my defined settings (columns, colors) etc for many versions prior to 2092. When I load SC prior to version 2094, the quoteboard would also open. Since 2094 this does not occur. Is there a setting somewhere to assure that my default quoteboard loads along with all my chartbooks? FYI, chartbooks all load at startup. Thank you |
[2020-05-01 18:23:03] |
This was an issue previous to 2098 but it has been resolved. We have just tested this with version 2098 (the current Pre-Release) and we do not see any problem. As long as the Quote Board is open when the Chartbook is saved and closed, then when reopening the chartbook, the Quote Board is also restored. Let us know if you are still having this issue in version 2098. To access a backup Chartbook with your saved Quote Boards, follow the instructions near the top of this thread here: Version 2093: New Chartbook Format, Better Data Management in Sub Instances, Other You will need to first go back to your backup Chartbook's and open them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-01 18:43:20] |
It does seem to be fixed in 2098. Thanks
