Date/Time: Wed, 18 Nov 2026 09:09:14 +0000
Chart Calculator CV Error
View Count: 912
[2020-04-29 17:07:04]
User98657 - Posts: 420
I'm using the Chart Calculator on an ES Chart (ESM20_FUT_CME). I'm measuring from 2906.50 up to 1940.
The DIT is correctly shown as +134, the PD is correctly shown as +33.50, the CV however is showing +10050.00. This would of course be 75 per tick, and obviously incorrect.
Chart>Chart Settings>Tick Size is set to .25
Chart>Chart Settings>Advanced Settings 2>Currency Value per Tick is set to 12.5.
Global Settings>Symbol Settings> Tick Size is set to .25 and Currency Value Per Tick is set to 12.5
Before sending this I checked my CL Chart as well and found the Currency value is x3 (should be showing 800 but instead shows 2400)
When I check it on a 5-Min Chart, I see a difference. My 5-Min chart shows the correct currency Value.
Thoughts?
[2020-04-29 20:41:49]
This is not an error, that value is affected by the Trade Window order quantity. Set the order quantity to 1.
The documentation says this here:
Chart Drawing Tools: Chart Calculator Configuration
