Date/Time: Wed, 18 Nov 2026 09:09:12 +0000
[Programming Help] - Charts
View Count: 940
| [2020-04-29 07:43:05] |
| User737360 - Posts: 23 |
Hi, I have set up a workspace and various templates. If I now select a template (M15), this will be changed on all charts. Can it be that all are linked and if so how can I change this? Best regards Noah |
| [2020-04-30 00:01:30] |
You need to disable chart linking. Refer to: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
