Date/Time: Sun, 13 Jul 2025 07:17:01 +0000
Alert Sound Problem
View Count: 1290
[2014-01-17 05:31:41] |
esMike - Posts: 74 |
I tried using "sc.PlaySound(1);" in a study if my conditions are met... And it plays the sound over and over like 10 times even though the conditions are not met. Adding this didn't change anything... "sc.AlertOnlyOncePerBar = 1;" As soon as I turn the alert on it plays the sound over and over. I know the problem isn't in the study because the study is drawing the signals properly where the alerts should sound. |
[2014-01-17 06:02:30] |
sc.PlaySound() is unrestricted. If you are hearing an alert sound over and over again, the issue is in your code. This is definite. Or you may not have set 1 for the number of times to play the sound file in Global Settings >> General Settings. "sc.AlertOnlyOncePerBar = 1;" does not apply to sc.PlaySound(). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
