Date/Time: Wed, 15 May 2024 14:25:28 +0000
Depth of Market Data FROZEN
View Count: 474
[2020-04-28 16:23:58] |
User355030 - Posts: 163 |
I'm using the Depth of Market Data study with my spreadsheet studies/trading and the data is frozen with yesterdays data?
[2020-04-28 18:37:55] |
Go to the chart, that the Spreadsheet Study is on and select File >> Open Market Depth Window. Do you see the market depth displayed there and updating?
[2020-04-28 19:01:55] |
We think we know what the problem is. We will have a solution implemented in the next release. For now display a smaller number of depth levels in the chart through this setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-28 19:02:18
