Date/Time: Sat, 11 May 2024 04:48:48 +0000
Some new SG DrawStyle requests
View Count: 567
[2020-04-26 20:10:35] |
@sstfrederik - Posts: 403 |
Hi, For a few studies I am creating I would like to see if you could add the following new SG Drawstyles in due time. Transparent versions for these four: DRAWSTYLE_SQUARE_OFFSET_LEFT_FOR_CANDLESTICK DRAWSTYLE_SQUARE_OFFSET_RIGHT_FOR_CANDLESTICK DRAWSTYLE_LEFT_SIDE_TICK_SIZE_RECTANGLE DRAWSTYLE_RIGHT_SIDE_TICK_SIZE_RECTANGLE Border with a transparent circle: DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE _WITH_BORDER Many thank for the consideration. Frederik |
[2020-04-27 19:02:24] |
We will see about these.
