Date/Time: Sat, 18 May 2024 22:03:57 +0000
System Notification Message
View Count: 440
[2020-04-25 00:59:59] |
User566851 - Posts: 18 |
Hi, --If I select "Do not Show Again" in the system notification message window will future new alert messages still appear? Is there a way to turn this on and off in general settings? Thank you. Extra Detail: Currently I see the message about CME market depth fees. I am done seeing this, but I would like to get future updates. |
[2020-04-25 07:25:33] |
Yes future messages will cause it to display. You can also display this anytime through Help >> Open system Message in Browser.
