Date/Time: Sun, 12 May 2024 00:12:37 +0000
Trade Activity Log Currency to Points
View Count: 619
[2020-04-24 20:57:44] |
User98657 - Posts: 304 |
For some reason i cannot get the Trade Activity Log to switch from Currency to Points when I change the settings in the P/L Format (Trades Tab). I've checked Charts>Chart Settings>Advanced Settings> Profit?Loss Format = Points(P) I've checked Charts>Chart Settings>Advanced Settings 2>Currency Value Per Tick = 12.5 I'm using SC Data and SC Order Routing, Version 2086-64. The Trade Activity Log shows currency, will not switch to Ticks or Points. OK.... I found that when I select "All Symbols (Non-Sim)", a blank row is created between my CLM20 data, and my ESM20 data. If i reset to only capture the ES, or the CL, that blank row goes away, and I can choose between Points, Ticks, or Currency. Is this by design? Date Time Of Last Edit: 2020-04-24 21:06:51
[2020-04-27 18:57:07] |
Refer to the documentation here: Trade Activity Log: Profit/Loss (P/L) Format Check the documentation first before posting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
