Date/Time: Sun, 19 May 2024 00:37:00 +0000
Volume Histogram of BUY/SELL
View Count: 1197
[2020-04-24 16:21:48] |
User228231 - Posts: 1 |
Sierra, is a powerhouse but everything is hidden and sometimes it takes ages just to find and setup the chart the way I like it. Now, I am trying to set up the chart for volume analysis and I have understood this is done by "Studies". Can someone let me know how to add histogram/bars at the bottom of chart that shows Volume Histogram of BUY/SELL? |
[2020-04-24 19:51:08] |
JohnR - User831573 - Posts: 300 |
Possibly the BidVolume vs AskVolume would work It is a built-in standard study (indicator). You can either have both above zero line or one above & one below. Hope this helps. JohnR |
SC_ScreenCap_Bid_Ask_Vol.jpg / V - Attached On 2020-04-24 19:49:14 UTC - Size: 226.19 KB - 339 views |
[2020-04-24 20:51:05] |
As mentioned in the prior post, this is the study you will want to use: Bid Volume vs Ask Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-24 20:51:41
[2020-04-24 23:13:44] |
User745789 - Posts: 173 |
JohnR mentioned both above zero line. Small feature request: if the difference subgraph could also show abs value in bars above zero line.
[2020-04-25 02:31:16] |
It is possible to see a graph of only difference, but it is both above / below zero, depending if bid or ask was greater. If you want both above zero and change color, I think you will have to modify some code. JohnR |
SC_Settings Diff of_Bid_Ask_Vol.jpg / V - Attached On 2020-04-25 02:29:43 UTC - Size: 269.94 KB - 282 views |
[2020-04-25 04:30:04] |
I can use the abs value study, but can't maintain the original +/- bar coloring, which is expected. Maybe could apply color bar alert to the original, then study overlay that on the abs value study.
[2020-04-25 07:14:33] |
Modify the code as you require. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
