Date/Time: Wed, 18 Nov 2026 09:17:12 +0000
Subgraph values don't appear in spreadsheet study columns in real time
View Count: 1188
[2020-04-23 21:52:21]
User787032 - Posts: 39
I have created a custom study that, based on price moves, draws lines using s_UseTool, connecting key price points on the chart. As the UseTool doesn’t print any subgraph values, I inserted subgraphs to hold values for the start and end bar and the start and end price values for each line drawing. These subgraph values appear correctly in the Chart Values window. However, if I add the spreadsheet study to the chart, the subgraph values don’t appear in the spreadsheet columns during a chart replay until the replay is paused or stopped.
Based on the spreadsheet study documentation, I have set the Calculation Precedence in the study to VERY_LOW_PREC_LEVEL, and the spreadsheet study is last in the list of Studies to Graph. Are there any other settings needed to allow the subgraph values to appear in the spreadsheet study columns in real time?
Thanks in advance for any help
[2020-04-24 05:36:37]
Definitely remove this:
And as long as the Spreadsheet Study is at the end of the list of Studies to Graph, we would expect the issue to be resolved.
If there still is an issue the next step is to check the calculation order:
Chart Studies: How Calculation Order of Studies Is Determined
Date Time Of Last Edit: 2020-04-24 08:31:57
[2020-04-24 19:10:05]
Unfortunately, that change didn't resolve the issue.
The study producing the subgraph values has a Calc Order of 3. the spreadsheet study has a calc order of 4 and is the last item in the list of Studies to Graph.
When the chart is running normally (i.e. not in a replay) the subgraph values do not appear in the spreadsheet columns until the chart is reloaded and recalculated.
[2020-04-24 19:17:39]
Okay this is an advanced issue that must definitely have something to do with study calculation order or something else we are not understanding. This is really just not within the scope of our support to be debugging the cause of in your case.
Date Time Of Last Edit: 2020-04-24 19:18:18
