Date/Time: Sat, 18 May 2024 22:46:07 +0000
trading from the DOM spreads
View Count: 667
[2020-04-23 18:36:13] |
User220914 - Posts: 239 |
Hi, having trouble trading directly from the chart dom on a spread with a symbol in oil. it is an exchange spread can you explain to me how to set this up thank you. this is on a second instance. thanks in advance I can pull up and chart the spread |
[2020-04-24 08:09:22] |
Do you have a problem with trading spreads on the main instance of Sierra Chart? What exactly is the trouble you are having? This is not clear for us.
[2020-04-24 16:44:39] |
good point. I Can trade them on the main instance. It says unknown symbol on the 2nd instance thank you. I will use the main instance for now. Do you know how i would look up the NOB bond spread ? exchange notes over bonds. thank you |
[2020-04-25 07:34:38] |
Regarding post #3, we will work on both of these issues.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-25 07:34:44
