Date/Time: Fri, 03 May 2024 06:19:12 +0000
Move a bracket
View Count: 572
[2020-04-23 00:08:46] |
BrewTrader - Posts: 21 |
I place a bracket order, 8 tick profit, 8 tick stop. If the order starts going in my favor I want to drag the order down (on the chart) and move both my profit and my stop at the same time, maintaining the 8/8 tick spread. Is there a way to do this?
[2020-04-23 19:31:49] |
Yes this is fully supported. You will just modify the order. Instructions: Chart Trading and the Chart DOM: Modifying and Canceling Orders on the Chart Let us know if you have any problem with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-26 02:12:18] |
User845052 - Posts: 75 |
I am trying to do this too and it is not clear to me where this is stated in your link
[2020-11-26 02:24:49] |
Assuming "Changing the Price of an Order" is the reference, I simply don't understand how to use it to move an entire bracket
