Date/Time: Thu, 16 May 2024 20:11:10 +0000
Does Denali support NYMEX WA and 7A (options on calendar spreads)
View Count: 492
[2020-04-22 20:02:43] |
ErikT - Posts: 117 |
NYMEX offers exchange-traded options on Crude Oil timespreads thruough the WAxxxx (delivery-settled) and 7A (cash-settled) contract series. But I cannot find these symbols in my Denali SC ORS feed using Find Symbol. If these contracts are supported by Denali, please advise how to find them using Find Symbol or otherwise. If they are not supported is there any chance of adding support for them if I am willing to pay for it? I would need access to several years of historical data for analysis purposes. Thanks Guys! |
[2020-04-23 19:33:57] |
If these are not already supported and we have to look, then we would have to set them up. In that case there would not be any historical data available. It would only begin as of the moment we set them up. At this point we recommend contacting the CME for this historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-23 19:34:19
[2020-04-23 20:09:26] |
Ok, got it. WIll look to other sources for historical data. It would still be awesome if you are able to support these contracts. Also possible they are already there and I just didn't find them. You have a "Get Spreads" function and a "Get Options" function. These are options on spreads. Doesn't really map to your design so far as I could tell, but it could be I was looking in the wrong place. Thanks for the quick reply guys! |
