Date/Time: Thu, 16 May 2024 19:55:10 +0000
historical intraday data stuck at yesterday
View Count: 530
[2020-04-22 15:09:00] |
User443459 - Posts: 4 |
I am testing with the free trial, and I read that the intraday data should be refreshed every ten minutes. However, I am stuck on 4/21 and there is already 2 hours the market is open. I went into the documentation and did what was explained, but obviously I am missing something. Any help?
[2020-04-22 18:33:18] |
What is the symbol of the chart. Select Edit >> Download Data from End of Chart. If the bars are filled in, then check that Global Settings >> Data/Trade Service Settings >> Service Settings >> Intraday Download Interval for Non-Real-time Symbols (min) is set as you expect. The lowest it can be set is 20 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-22 18:33:28
[2020-04-22 19:05:43] |
Thank you for your answer, I had already done that. I found out it was the start time of the session that was set 13.30 because I downloaded the software middle day. By changing start time at 00.00.00 , everything worked well.
[2020-04-23 03:12:34] |
When you download Sierra Chart it does not have any effect on Session Times. There is another reason why it was set to that. Maybe there was a change in time zone settings.
