Date/Time: Thu, 02 May 2024 17:48:01 +0000
free trial
View Count: 1842
[2013-04-15 14:18:18] |
eldadbd - Posts: 1 |
Hi I had a free trial long ago and I WANT TO REVIEW AGAIN IF YOUR SOFTWARE IS THE RIGHT ONE FOR ME AFTER A DISAPPOINTMENT WITH ESIGNAL - COULD I PLS. TRY IT AGAIN? Date Time Of Last Edit: 2013-04-15 14:18:57
[2013-04-15 16:19:17] |
We have set your account for a new trial. Restart Sierra Chart. Log into Sierra Chart using the very same login information you used to log into this Support Board with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-17 13:04:52] |
You are now using a different Sierra Chart account. You need to use this Account Name: eldadbd
