Date/Time: Thu, 16 May 2024 07:12:51 +0000
SC Replay Issue - Order fills not synchronised with replay time
View Count: 851
[2020-04-22 04:33:17] |
Vitwat - Posts: 19 |
Hi, After I installed the 2088 version, I have been experiencing unsynchronized order fills during replay (on SC Data - All services). I have attached a screenshot of my chart, and you will see that the buy limit order (23529) had been filled before the bar even touched it. You will also see that even though the price has exceeded my target (Sell limit order at 23609), the order is still not filled. http://www.sierrachart.com/image.php?Image=1587529843156.png Could you please look into this and guide me to the solution? Thanks. Vitwat Date Time Of Last Edit: 2020-04-23 10:45:36
Attachment Deleted. Sierra_Chart_Replay_Problem.png / V - Attached On 2020-04-22 04:23:13 UTC - Size: 37.16 KB - 234 views |
[2020-04-22 05:41:05] |
jaxscott - Posts: 57 |
I have also had this problem as soon as I updated to version 2088. Downgrading to 2086 solves the problem for me.
[2020-04-22 09:42:51] |
The issue has been fixed in the 2089 version, s I have removed my post.
[2020-04-23 10:46:07] |
This problem should be resolved in version 2091. Instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
