Date/Time: Fri, 26 Apr 2024 21:51:58 +0000
How to add/ trade NQ's using AMP/TTNet?
View Count: 1437
[2014-01-15 15:16:30] |
User29698 - Posts: 28 |
I am using Sierrachart with AMP/TTNet. In the pre-populated symbol list, I cannot find NQ or YM futures. ES are there and not a prblem. How do I add/ trade NQ's and YM's in Sierrachart using AMP/TTNet?
[2014-01-15 17:02:43] |
The symbols should definitely be there. Perform a Full Reset of the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-15 17:19:22] |
Well, they are definitely NOT there. That is why I am posting. Have performed reset as described and this has not changed anything.
[2014-01-15 17:28:54] |
P.S. I did a remote support call with AMP and they could not locate the symbols for NQ's and YM's either. It was the AMP support team that suggested that I should contact you guys.
[2014-01-15 17:36:13] |
Restart Sierra Chart. And then perform a Full Reset of the symbol settings again as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this provide a copy of the Message Log, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-15 18:37:09] |
Done and no change. Still no NQ's and YM's in the symbol list. See message log below. ***************************************** Software version: 1074 | 2014-01-15 19:34:19 Enabled for: Sierra Chart Historical Data Service. | 2014-01-15 19:34:19 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-01-15 19:34:19 Active service: AMP/TTNet | 2014-01-15 19:34:19 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-01-15 19:34:19 2014-01-15 19:34:19 Local computer clock time | 2014-01-15 19:34:19 2014-01-15 18:34:19 GMT time | 2014-01-15 19:34:19 2014-01-15 19:34:19 Time zone adjusted time | 2014-01-15 19:34:19 Time difference to server time: 1 seconds. | 2014-01-15 19:34:19 Program path: C:\SierraChart\ | 2014-01-15 19:34:19 Data Files path: C:\SierraChart\Data\ | 2014-01-15 19:34:19 OS Version Number: 6.1 | 2014-01-15 19:34:19 Checking for new symbol settings for ttamp | 2014-01-15 19:34:19 HD Request # 2 - Downloading Intraday chart data for R2000 Ind Mini-Mar14-ICE_IPE to the file R2000 Ind Mini-Mar14-ICE_IPE.scid. Service: ttamp | 2014-01-15 19:34:23 HD Request # 2 - Download start Date-Time: 2014-01-15 19:32:26.0 | 2014-01-15 19:34:23 HD Request # 2 - Using server: ttamp.sierracharts.com port 10149 | 2014-01-15 19:34:23 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-15 19:34:23 HD Request # 3 - Downloading Historical Daily chart data for RJH14. Starting date: 2014-01-14. Service: ttamp | 2014-01-15 19:34:23 HD Request # 3 - Requesting historical Daily data for RJH14 starting at 2014-01-13 | 2014-01-15 19:34:23 The network socket is connected. | 2014-01-15 19:34:23 HD Request # 2 - Sending historical data logon request message. | 2014-01-15 19:34:23 HD Request # 3 - Receiving historical Daily data for RJH14 starting at 2014-01-13 | 2014-01-15 19:34:24 Writing historical Daily data for RJH14 to the file RJH14.dly | 2014-01-15 19:34:24 HD Request # 3 - Received 3 records from 2014-01-13 00:00:00 to 2014-01-15 00:00:00 (3.0 days) and wrote 2 records for RJH14 | 2014-01-15 19:34:24 HD Request # 3 - Daily download COMPLETE for RJH14 | 2014-01-15 19:34:24 HD Request # 2 - Requesting up to 100 days of Intraday data. Record interval: 1 | 2014-01-15 19:34:24 The network socket for historical data has been closed. | 2014-01-15 19:34:24 HD Request # 2 - Historical data for R2000 Ind Mini-Mar14-ICE_IPE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-01-15 19:34:24 HD Request # 2 - Received 0 records and wrote 0 records for R2000 Ind Mini-Mar14-ICE_IPE | 2014-01-15 19:34:24 HD Request # 2 - Intraday download COMPLETE for R2000 Ind Mini-Mar14-ICE_IPE | 2014-01-15 19:34:24 HD Request # 4 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2014-01-15 19:34:24 HD Request # 4 - Download start Date-Time: 2014-01-15 19:32:28.0 | 2014-01-15 19:34:24 HD Request # 4 - Using server: ds3.sierracharts.com port 10149 | 2014-01-15 19:34:24 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-15 19:34:24 The network socket is connected. | 2014-01-15 19:34:24 HD Request # 4 - Sending historical data logon request message. | 2014-01-15 19:34:24 HD Request # 4 - Requesting up to 100 days of Intraday data. Record interval: 1 | 2014-01-15 19:34:25 HD Request # 4 - Decompressing data. | 2014-01-15 19:34:25 HD Request # 4 - Receiving Intraday data for $TICK starting at 2014-01-15 19:32:28 | 2014-01-15 19:34:25 HD Request # 4 - Timestamp of first Intraday data file record written: 2014-01-15 19:32:28 | 2014-01-15 19:34:25 The network socket for historical data has been closed. | 2014-01-15 19:34:25 HD Request # 4 - Historical data for $TICK is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-01-15 19:34:25 HD Request # 4 - Received 117 records from 2014-01-15 19:32:28 to 2014-01-15 19:34:24 (116.0 seconds) and wrote 117 records for $TICK | 2014-01-15 19:34:25 HD Request # 4 - Intraday download COMPLETE for $TICK | 2014-01-15 19:34:25 AMP/TTNet: Connecting. | 2014-01-15 19:34:25 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2014-01-15 19:34:25 The network socket is connected. | 2014-01-15 19:34:25 TT Price Feed FIX Session: Sending the Logon message. | 2014-01-15 19:34:25 TT FIX Price Feed session connected. | 2014-01-15 19:34:26 Starting the Orders session. Connecting to 12.41.48.53 port 10500... | 2014-01-15 19:34:26 The network socket is connected. | 2014-01-15 19:34:26 TT Orders FIX Session: Sending the Logon message. | 2014-01-15 19:34:26 TT FIX Orders session connected. | 2014-01-15 19:34:26 AMP/TTNet: Connected. | 2014-01-15 19:34:26 AMP/TTNet - Starting real-time market data updates for: R2000 Ind Mini-Mar14-ICE_IPE | 2014-01-15 19:34:26 Requesting market data for R2000 Ind Mini-Mar14-ICE_IPE. Depth levels: 1 | 2014-01-15 19:34:26 HD Request # 5 - Downloading Intraday chart data for R2000 Ind Mini-Mar14-ICE_IPE to the file R2000 Ind Mini-Mar14-ICE_IPE.scid. Service: ttamp | 2014-01-15 19:34:26 HD Request # 5 - Download start Date-Time: 2014-01-15 19:32:26.0 | 2014-01-15 19:34:26 HD Request # 5 - Using server: ttamp.sierracharts.com port 10149 | 2014-01-15 19:34:26 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-15 19:34:26 SC Market Stats - Starting real-time market data updates for: $TICK | 2014-01-15 19:34:26 SC Market Stats: Connecting to the server ds5.sierracharts.com. Port 443 | 2014-01-15 19:34:26 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-01-15 19:34:26 TT Gateway Status: Price server for the CME-A exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the CME-A exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the CME-A exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Price server for the CME exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the CME exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the CME exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Price server for the Eurex-B exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the Eurex-B exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the Eurex-B exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Price server for the Eurex-C exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the Eurex-C exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the Eurex-C exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Price server for the ICE_IPE-A exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the ICE_IPE-A exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the ICE_IPE-A exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Price server for the ICE_IPE exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the ICE_IPE exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the ICE_IPE exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Price server for the TTSIM exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Order server for the TTSIM exchange is Open | 2014-01-15 19:34:27 TT Gateway Status: Fill server for the TTSIM exchange is Open | 2014-01-15 19:34:27 The network socket is connected. | 2014-01-15 19:34:27 HD Request # 5 - Sending historical data logon request message. | 2014-01-15 19:34:27 The network socket is connected. | 2014-01-15 19:34:27 SC Market Stats: Connected to server. | 2014-01-15 19:34:27 SC Market Stats: Sending logon request message. | 2014-01-15 19:34:27 HD Request # 5 - Requesting up to 100 days of Intraday data. Record interval: 1 | 2014-01-15 19:34:27 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-01-15 19:34:27 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-01-15 19:34:27 SC Market Stats - Successfully connected. | 2014-01-15 19:34:27 Restarting real-time data updates for symbol: $TICK | 2014-01-15 19:34:27 HD Request # 5 - Decompressing data. | 2014-01-15 19:34:27 HD Request # 5 - Receiving Intraday data for R2000 Ind Mini-Mar14-ICE_IPE starting at 2014-01-15 19:32:26 | 2014-01-15 19:34:27 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-01-15 19:32:26 | 2014-01-15 19:34:27 The network socket for historical data has been closed. | 2014-01-15 19:34:27 HD Request # 5 - Received 26 records from 2014-01-15 19:32:26 to 2014-01-15 19:34:26 (120.0 seconds) and wrote 26 records for R2000 Ind Mini-Mar14-ICE_IPE | 2014-01-15 19:34:27 Added 1 Time and Sales records to Intraday data file for R2000 Ind Mini-Mar14-ICE_IPE after download. | 2014-01-15 19:34:27 HD Request # 5 - Intraday download COMPLETE for R2000 Ind Mini-Mar14-ICE_IPE | 2014-01-15 19:34:27 Real-time Intraday chart data file updates started for R2000 Ind Mini-Mar14-ICE_IPE | 2014-01-15 19:34:27 HD Request # 6 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2014-01-15 19:34:27 HD Request # 6 - Download start Date-Time: 2014-01-15 19:34:24.0 | 2014-01-15 19:34:27 HD Request # 6 - Using server: ds3.sierracharts.com port 10149 | 2014-01-15 19:34:27 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-15 19:34:27 The network socket is connected. | 2014-01-15 19:34:27 HD Request # 6 - Sending historical data logon request message. | 2014-01-15 19:34:27 HD Request # 6 - Requesting up to 100 days of Intraday data. Record interval: 1 | 2014-01-15 19:34:28 HD Request # 6 - Decompressing data. | 2014-01-15 19:34:28 HD Request # 6 - Receiving Intraday data for $TICK starting at 2014-01-15 19:34:24 | 2014-01-15 19:34:28 HD Request # 6 - Timestamp of first Intraday data file record written: 2014-01-15 19:34:24 | 2014-01-15 19:34:28 The network socket for historical data has been closed. | 2014-01-15 19:34:28 HD Request # 6 - Received 4 records from 2014-01-15 19:34:24 to 2014-01-15 19:34:27 (3.0 seconds) and wrote 4 records for $TICK | 2014-01-15 19:34:28 HD Request # 6 - Intraday download COMPLETE for $TICK | 2014-01-15 19:34:28 Real-time Intraday chart data file updates started for $TICK | 2014-01-15 19:34:28 AMP/TTNet - Starting real-time market data updates for: ES-201403-CME | 2014-01-15 19:34:35 Requesting market data for ES-201403-CME. Depth levels: 1 | 2014-01-15 19:34:35 HD Request # 7 - Downloading Intraday chart data for ES-201403-CME to the file ES-201403-CME.scid. Service: ttamp | 2014-01-15 19:34:35 HD Request # 7 - Download start Date-Time: 2014-01-15 19:32:27.0 | 2014-01-15 19:34:35 HD Request # 7 - Using server: ttamp.sierracharts.com port 10149 | 2014-01-15 19:34:35 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-15 19:34:35 HD Request # 8 - Downloading Historical Daily chart data for ESH14. Starting date: 2014-01-14. Service: ttamp | 2014-01-15 19:34:35 HD Request # 8 - Requesting historical Daily data for ESH14 starting at 2014-01-13 | 2014-01-15 19:34:35 The network socket is connected. | 2014-01-15 19:34:35 HD Request # 7 - Sending historical data logon request message. | 2014-01-15 19:34:35 HD Request # 8 - Receiving historical Daily data for ESH14 starting at 2014-01-13 | 2014-01-15 19:34:35 Writing historical Daily data for ESH14 to the file ESH14.dly | 2014-01-15 19:34:35 HD Request # 8 - Received 3 records from 2014-01-13 00:00:00 to 2014-01-15 00:00:00 (3.0 days) and wrote 2 records for ESH14 | 2014-01-15 19:34:35 HD Request # 8 - Daily download COMPLETE for ESH14 | 2014-01-15 19:34:35 HD Request # 7 - Requesting up to 100 days of Intraday data. Record interval: 1 | 2014-01-15 19:34:35 HD Request # 7 - Decompressing data. | 2014-01-15 19:34:36 HD Request # 7 - Receiving Intraday data for ES-201403-CME starting at 2014-01-15 19:32:27 | 2014-01-15 19:34:36 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-01-15 19:32:27 | 2014-01-15 19:34:36 The network socket for historical data has been closed. | 2014-01-15 19:34:36 HD Request # 7 - Received 79 records from 2014-01-15 19:32:27 to 2014-01-15 19:34:34 (2.1 minutes) and wrote 79 records for ES-201403-CME | 2014-01-15 19:34:36 Added 1 Time and Sales records to Intraday data file for ES-201403-CME after download. | 2014-01-15 19:34:36 HD Request # 7 - Intraday download COMPLETE for ES-201403-CME | 2014-01-15 19:34:36 Real-time Intraday chart data file updates started for ES-201403-CME | 2014-01-15 19:34:36 AMP/TTNet - Starting real-time market data updates for: GC-201402-CME | 2014-01-15 19:34:41 Requesting market data for GC-201402-CME. Depth levels: 1 | 2014-01-15 19:34:41 HD Request # 9 - Downloading Intraday chart data for GC-201402-CME to the file GC-201402-CME.scid. Service: ttamp | 2014-01-15 19:34:41 HD Request # 9 - Download start Date-Time: 2014-01-15 19:32:27.0 | 2014-01-15 19:34:41 HD Request # 9 - Using server: ttamp.sierracharts.com port 10149 | 2014-01-15 19:34:41 HD Request # 10 - Downloading Historical Daily chart data for GCG14. Starting date: 2014-01-14. Service: ttamp | 2014-01-15 19:34:41 HD Request # 10 - Requesting historical Daily data for GCG14 starting at 2014-01-13 | 2014-01-15 19:34:41 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-15 19:34:41 The network socket is connected. | 2014-01-15 19:34:41 HD Request # 9 - Sending historical data logon request message. | 2014-01-15 19:34:41 HD Request # 10 - Receiving historical Daily data for GCG14 starting at 2014-01-13 | 2014-01-15 19:34:41 Writing historical Daily data for GCG14 to the file GCG14.dly | 2014-01-15 19:34:41 HD Request # 10 - Received 3 records from 2014-01-13 00:00:00 to 2014-01-15 00:00:00 (3.0 days) and wrote 2 records for GCG14 | 2014-01-15 19:34:41 HD Request # 10 - Daily download COMPLETE for GCG14 | 2014-01-15 19:34:41 HD Request # 9 - Requesting up to 100 days of Intraday data. Record interval: 1 | 2014-01-15 19:34:41 HD Request # 9 - Decompressing data. | 2014-01-15 19:34:42 HD Request # 9 - Receiving Intraday data for GC-201402-CME starting at 2014-01-15 19:32:27 | 2014-01-15 19:34:42 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-01-15 19:32:27 | 2014-01-15 19:34:42 The network socket for historical data has been closed. | 2014-01-15 19:34:42 HD Request # 9 - Received 34 records from 2014-01-15 19:32:27 to 2014-01-15 19:34:41 (2.2 minutes) and wrote 34 records for GC-201402-CME | 2014-01-15 19:34:42 HD Request # 9 - Intraday download COMPLETE for GC-201402-CME | 2014-01-15 19:34:42 Real-time Intraday chart data file updates started for GC-201402-CME | 2014-01-15 19:34:42 |
[2014-01-15 18:41:04] |
If you actually did a Full Reset, then this log is indicating there is a communication problem from your side to the Sierra Chart server. What operating system are you running and if you have any firewall software running on the computer, disable it. The Windows firewall is OK and does not have to be disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-15 18:41:29
[2014-01-15 18:46:42] |
I did a full rest as per instructions. I am running Windows 7 and do not have a firewall other than the Windows one. I am also running Avira Anti-Virus, but that should not affect comms.
[2014-01-15 18:49:22] |
Just did another full rest and NQ and YM are now available. So all seems to be solved. Thank you for your help.
[2014-01-15 20:25:27] |
When you press the Full Reset button on the Global Symbol Settings window, the list of symbols will be cleared. And then new symbols will be downloaded. How long did it take for the list to fill back up? It should be done in just a few seconds. It may take longer and you will need to wait until the list fills. And then after this you must press OK. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-15 20:26:03
