Date/Time: Thu, 16 May 2024 00:25:19 +0000
Chart DOM order management
View Count: 489
[2020-04-18 18:36:09] |
User135370 - Posts: 160 |
Hi Sierra I have to say the Chart DOM is a fantastic tool and full customizable too which is awesome. Could you look at allowing more control of the order management. Currently you can place orders on the DOM but they appear on the chart not the DOM itself to move an order you must do it from the chart to cancel an order you either have to cancel all or close the order from the chart which is far left and the DOM is far right. It would fantastic if all this can be done on the Chart DOM. |
[2020-04-19 08:07:26] |
Have a look at this setting: Chart Settings: Align Trade Drawings Text to Right (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
