Date/Time: Wed, 15 May 2024 06:14:13 +0000
Denali Feed Delayed?
View Count: 464
[2020-04-18 03:39:58] |
User150857 - Posts: 2 |
Hello New to Sierra Chart so forgive me if this is a dumb question. I am using the Sierra Chart Futures Order Routing Service With Data and the Denali data feed. I think my data is delayed in both simulation mode and live mode. It should be real time in both shouldn't it? The info line at the top of my charts has the [M] next to the symbol, which to my understanding means it is using the Denali feed, but then later on it has the a time with (delayed) following it. I've attached screenshots of my data feed settings and the line of info from the top of a chart where it says delayed. Any help would be appreciated. |
DataTradeServiceSettings.PNG / V - Attached On 2020-04-18 03:32:37 UTC - Size: 33.95 KB - 192 views Delayed.PNG / V - Attached On 2020-04-18 03:32:44 UTC - Size: 5.15 KB - 156 views |
[2020-04-18 11:52:32] |
That is because the market is now closed. You can disregard the delay time.
