Date/Time: Sat, 27 Apr 2024 03:34:52 +0000
Unable to connect to IB (SC v1077)
View Count: 1260
[2014-01-15 12:29:39] |
BataviaTrader - Posts: 63 |
IB status window says I'm connected to IB. However, after I also open SC the log reports 'unable to connect, trying to reconnect time after time, without result. This issue comes out of the blue, I have no idea for what reason. Below you find the Logs Report. Please advice what to do. Thank you in advance. ----- Software version: 1077 | 2014-01-15 06:21:04 Usage end date: 2014-04-21 | 2014-01-15 06:21:04 Enabled for: Sierra Chart Historical Data Service. | 2014-01-15 06:21:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-01-15 06:21:04 Active service: Interactive Brokers | 2014-01-15 06:21:04 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-01-15 06:21:04 2014-01-15 13:21:04 Local computer clock time | 2014-01-15 06:21:04 2014-01-15 12:21:04 GMT time | 2014-01-15 06:21:04 2014-01-15 06:21:04 Time zone adjusted time | 2014-01-15 06:21:04 Time difference to server time: 0 seconds. | 2014-01-15 06:21:04 Program path: C:\SierraChart\ | 2014-01-15 06:21:04 Data Files path: C:\SierraChart\Data\ | 2014-01-15 06:21:04 OS Version Number: 6.1 | 2014-01-15 06:21:04 Checking for new symbol settings for ib | 2014-01-15 06:21:04 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:10 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:11 Failed to connect to the data and trade server. | 2014-01-15 06:21:11 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:11 Disconnected from IB. | 2014-01-15 06:21:11 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:11 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:16 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:17 Failed to connect to the data and trade server. | 2014-01-15 06:21:17 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:17 Disconnected from IB. | 2014-01-15 06:21:17 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:17 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:22 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:23 Failed to connect to the data and trade server. | 2014-01-15 06:21:23 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:23 Disconnected from IB. | 2014-01-15 06:21:23 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:23 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:28 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:29 Failed to connect to the data and trade server. | 2014-01-15 06:21:29 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:29 Disconnected from IB. | 2014-01-15 06:21:29 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:29 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:34 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:35 Failed to connect to the data and trade server. | 2014-01-15 06:21:35 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:35 Disconnected from IB. | 2014-01-15 06:21:35 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:35 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:40 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:41 Failed to connect to the data and trade server. | 2014-01-15 06:21:41 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:41 Disconnected from IB. | 2014-01-15 06:21:41 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:41 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:46 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:47 Failed to connect to the data and trade server. | 2014-01-15 06:21:47 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:47 Disconnected from IB. | 2014-01-15 06:21:47 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:47 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:52 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:53 Failed to connect to the data and trade server. | 2014-01-15 06:21:53 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:53 Disconnected from IB. | 2014-01-15 06:21:53 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:53 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:21:58 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:21:59 Failed to connect to the data and trade server. | 2014-01-15 06:21:59 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:21:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:21:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:21:59 Disconnected from IB. | 2014-01-15 06:21:59 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:21:59 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:04 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:05 Failed to connect to the data and trade server. | 2014-01-15 06:22:05 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:05 Disconnected from IB. | 2014-01-15 06:22:05 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:05 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:10 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:11 Failed to connect to the data and trade server. | 2014-01-15 06:22:11 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:11 Disconnected from IB. | 2014-01-15 06:22:11 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:11 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:16 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:17 Failed to connect to the data and trade server. | 2014-01-15 06:22:17 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:17 Disconnected from IB. | 2014-01-15 06:22:17 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:17 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:22 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:23 Failed to connect to the data and trade server. | 2014-01-15 06:22:23 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:23 Disconnected from IB. | 2014-01-15 06:22:23 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:23 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:28 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:29 Failed to connect to the data and trade server. | 2014-01-15 06:22:29 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:29 Disconnected from IB. | 2014-01-15 06:22:29 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:29 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:34 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:35 Failed to connect to the data and trade server. | 2014-01-15 06:22:35 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:35 Disconnected from IB. | 2014-01-15 06:22:35 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:35 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:40 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:42 Failed to connect to the data and trade server. | 2014-01-15 06:22:42 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:42 Disconnected from IB. | 2014-01-15 06:22:42 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:42 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:47 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:48 Failed to connect to the data and trade server. | 2014-01-15 06:22:48 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:48 Disconnected from IB. | 2014-01-15 06:22:48 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:53 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:22:54 Failed to connect to the data and trade server. | 2014-01-15 06:22:54 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:22:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:22:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:22:54 Disconnected from IB. | 2014-01-15 06:22:54 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:22:54 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:22:59 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:00 Failed to connect to the data and trade server. | 2014-01-15 06:23:00 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:00 Disconnected from IB. | 2014-01-15 06:23:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:00 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:05 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:06 Failed to connect to the data and trade server. | 2014-01-15 06:23:06 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:06 Disconnected from IB. | 2014-01-15 06:23:06 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:06 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:11 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:12 Failed to connect to the data and trade server. | 2014-01-15 06:23:12 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:12 Disconnected from IB. | 2014-01-15 06:23:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:12 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:17 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:18 Failed to connect to the data and trade server. | 2014-01-15 06:23:18 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:18 Disconnected from IB. | 2014-01-15 06:23:18 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:18 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:23 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:24 Failed to connect to the data and trade server. | 2014-01-15 06:23:24 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:24 Disconnected from IB. | 2014-01-15 06:23:24 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:24 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:29 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:30 Failed to connect to the data and trade server. | 2014-01-15 06:23:30 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:30 Disconnected from IB. | 2014-01-15 06:23:30 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:30 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:35 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:36 Failed to connect to the data and trade server. | 2014-01-15 06:23:36 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:36 Disconnected from IB. | 2014-01-15 06:23:36 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:36 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:41 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:42 Failed to connect to the data and trade server. | 2014-01-15 06:23:42 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:42 Disconnected from IB. | 2014-01-15 06:23:42 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:42 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:47 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:48 Failed to connect to the data and trade server. | 2014-01-15 06:23:48 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:48 Disconnected from IB. | 2014-01-15 06:23:48 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:53 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:23:54 Failed to connect to the data and trade server. | 2014-01-15 06:23:54 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:23:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:23:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:23:54 Disconnected from IB. | 2014-01-15 06:23:54 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:23:54 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:23:59 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:24:00 Failed to connect to the data and trade server. | 2014-01-15 06:24:00 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:24:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:24:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:24:00 Disconnected from IB. | 2014-01-15 06:24:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:24:01 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:24:06 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:24:07 Failed to connect to the data and trade server. | 2014-01-15 06:24:07 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:24:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:24:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:24:07 Disconnected from IB. | 2014-01-15 06:24:07 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:24:07 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-15 06:27:07 Error received in OnConnect while connecting. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2014-01-15 06:27:08 Failed to connect to the data and trade server. | 2014-01-15 06:27:08 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-01-15 06:27:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-15 06:27:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-15 06:27:08 Disconnected from IB. | 2014-01-15 06:27:08 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-15 06:27:08 |
[2014-01-15 17:30:53] |
Refer to the instructions at step 15 here: http://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-15 17:32:18
