Date/Time: Fri, 03 May 2024 11:22:13 +0000
Chartbook issue
View Count: 1942
[2013-04-15 13:30:17] |
User23815 - Posts: 209 |
I started SC this morning and I try to load my primary Chartbook. I get the message: The Chartbook is not a valid Chartbook. The path it lists is correct. The file is in the Date file in SC. I tried restoring the file. Other Chartbooks do load. The size of the file in Data looks correct in comparison to the other .cht files. . I also downloaded the latest version. Help please |
[2013-04-15 16:14:06] |
Use a backup Chartbook file: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
