Date/Time: Mon, 13 May 2024 19:07:30 +0000
Detecting a modification on chart within ACSIL
View Count: 583
[2020-04-16 08:51:06] |
ACWalker - Posts: 6 |
Hello, 1.) I have been trying to look for a solid way of detecting whether the user has modified the price on the chart (by dragging the price level) through ACSIL, as I am working on a position sizer. I thought potentially using pointer events somehow but I could not see a way to do it that way. Is there any built in functionality to assist with this? 2.) I have been setting the target and stop price as a set price (not an offset) as part of an attached order. However, there is still automatic movement of stop and target when adjusting the price on an attached order by the same offset, is there a way to disable this? Thanks |
[2020-04-17 11:12:51] |
1. Do you mean like performing an Interactive Scale or Move operation? 2. We will have to add an option for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-17 11:21:53] |
1.) Potentially the move operation. Say we have a stop at 100, the user drags the entry price down to 95. I would like to be able to detect that there has been a modification (price difference of 5), so I can adjust some calculations. 2.) If it is viable for you, that would be useful! |
[2020-04-20 07:17:42] |
1. If there is a change with an order, the study function will get called: Working with ACSIL Arrays and Understanding Looping: When the Study Function is Called 2. We will add this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-20 07:18:18
[2020-04-26 10:13:23] |
1.) Thanks for your help, this has been fixed now. 2.) Again thank you, would you let me know when this feature has been made available? |
[2020-04-26 11:14:29] |
2. We will get this out into the next prerelease.
