Date/Time: Sat, 11 May 2024 05:15:53 +0000
Save as greyed out
View Count: 1102
[2020-04-16 00:57:44] |
jwick - Posts: 142 |
I opened an existing chartbook. Then created a new chartbook. Then duplicated various charts (deleting those charts in the original chartbook as I went along) to the new chartbook. Switched to the new chartbook and "Save" and "Save As" are both greyed out? I am able to call those functions from the original chartbook. I only have these two chartbooks open. https://i.imgur.com/cVy1e9k.png version 2080 |
[2020-04-16 07:08:39] |
It is hard from us to understand this without actually seeing what is going on in regards to open charts and chartbooks. But use File >> Save All to save all open Chartbooks.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-16 07:09:06
[2020-04-16 19:22:47] |
I played around with the scenario and believe I can reproduce it consistently and resolve it (which suggests a minor bug?). Every time I: a) Create a new chartbook (I) b) ONLY populate chartbook (I) with charts duplicated from a second chartbook (II) The Save, Save As options are greyed out while I have chartbook (I) selected (as though SC believes no charts exist in the chartbook and hence saving doesn't make sense). As soon as I create a chart manually within chartbook (I), the save options are selectable. |
[2020-04-16 19:42:59] |
We are looking this over.
