Date/Time: Fri, 10 May 2024 07:10:18 +0000
TPO
View Count: 419
[2020-04-16 00:11:59] |
User850090 - Posts: 26 |
I used to use Sierra like 3 years ago. I wanna use it again but when I load my old charts they won't show TPO what I set up years ago. It shows just empty chart. Thanks
[2020-04-16 18:49:35] |
Remove the TPO Profile Chart study from the chart. Do you see chart bars?
