Date/Time: Wed, 15 May 2024 07:33:05 +0000
charts acting erratically
View Count: 417
[2020-04-15 13:17:34] |
Anapurna - Posts: 10 |
Hi, my ES, CL and GC charts have been jumping back in time sporadically to earlier in the day or overnight. I have to tap "End" repeatedly to get back to the present. I replaced them today with backup versions from last week that seemed to not have problems, but to no avail. Is this a data issue? Or one of my studies maybe in all 3 charts, (they have all the same studies and study overlays, but referencing different charts). Strange that all 3 were having same problem though. Before I rebuild, want to make sure it is not some kind of data issue. Please advise. Thank you! |
[2020-04-15 19:11:22] |
This is not a data issue. Most likely this relates to the Chart Values tool. Make sure you remove the checkmark from Tools >> Synchronize Charts.
