Date/Time: Wed, 30 Sep 2026 08:20:41 +0000
Slow Update on Forex Graphic
View Count: 777
| [2020-04-13 20:45:05] |
| dangles - Posts: 5 |
Hello again. I am having problems with data update on EURUSD graphic. Clock or TR Bar countdown stops and bars freeze. There's something than I'm doing wrong? I'm doing the same than on Futures Graphics. Thank you |
| [2020-04-14 01:24:25] |
Refer to this help topic here about this: Prices / Data Falling Behind What you see might be normal but it is hard to say because we do not know how long of a delay you notice between updates and the time of day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-14 01:25:02
