Date/Time: Sat, 18 May 2024 06:48:38 +0000
time fill problem in simulated mode
View Count: 442
[2020-04-13 10:00:33] |
anouar6869 - Posts: 13 |
Hi support, I have update from 1978 to 2083 version. DateTime of the fill in the Trade Activity Log is wrong when trading from sub instance.(server in simulation mode on and sub instance with trade simulation disabled). For example instead of a fill at 5:35:03.244(pc clock) show something like 5:35:01.001(always in advance). Tested on a clean installed version of Sierrachart with the SC Data All Services data feed. Thanks |
[2020-04-13 10:32:21] |
That fill time will be based upon the actual update time of the underlying price data which triggered the fill. So what you are seeing is definitely correct.
