Date/Time: Sat, 18 May 2024 06:48:46 +0000
how do you turn off auto sizing dom columns?
View Count: 656
[2020-04-12 21:59:44] |
user10000 - Posts: 41 |
Certain columns are grayed out and wont allow me to turn off the auto sizing. Is there something i can do for this?
[2020-04-13 10:41:00] |
You just have to manually change the size and then Automatic sizing becomes disabled. Refer to: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
