Date/Time: Sat, 18 May 2024 16:54:22 +0000
How to Reverse nested bracket order?
View Count: 759
[2020-04-12 21:52:28] |
User254520 - Posts: 11 |
I am trying to reverse a bracket order with two OCO and BE settings. Can't find any documentation for existing code/function to do it in one line instead of having to order the opposite twice and track down / cancel all the child orders. *Not asking about DOM button, the question is for automated trading* Thank you |
[2020-04-13 07:35:57] |
So you want to cancel an existing bracket order and replace it with another one with the opposite side? We are not sure what a nested bracket order is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-13 19:41:06] |
Example would be: If I am in a +2 position, and I want to be a -2 on the same exact level with previous child orders cancelled and new ones initiated in the opposite direction. Exactly what a Reverse button does, but instead of getting out flat and entering at Market, I want to get out and immediately get in on the same level I initiated the position ( when the price gets to it ofc ) |
