Date/Time: Sun, 19 May 2024 14:15:16 +0000
Visual Studio 64 Bit Compilation
View Count: 1125
[2020-04-10 16:57:16] |
FerroTrader - Posts: 70 |
Hello to you all. Is it possible that SierraChart Support or anyone else here could post a step-by-step guide to compile a 64 bit DLL using Visual Studio ? It is necessary for all of us, I think. Thanks a lot. Andrea |
[2020-04-10 21:16:34] |
The easiest thing to do is to use the build functionality within Sierra Chart which can use Visual C++. Refer to step 19 here: Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function So make sure you are running the 64-bit version of Sierra Chart. And also you should be asking for help from Microsoft for this. You should not be asking for help here. We do not support Microsoft trash. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-10 21:18:39
