Date/Time: Sat, 27 Apr 2024 23:14:23 +0000
[User Discussion] - Other than FXCM Broker realtime FX data, what else we can use ?
View Count: 2415
[2013-04-15 11:19:25] |
FH87 - Posts: 43 |
This broker is Suck, cause it data is inaccurate Look at 1hr Eurusd data the spike up data Can Sierra give other choice of free FX data ? Date Time Of Last Edit: 2013-04-15 11:21:04
[2013-04-15 13:52:02] |
AndyL - Posts: 119 |
I think the data is fine, by and large. You are probably looking at the open yesterday (sunday). FXCM starts streaming data 2 hours earlier than most other brokers. If you set session start time to 17:00 New York timezone the chart should look like everywhere else.
[2013-04-16 05:36:13] |
FH87 - Posts: 43 |
If broker is not clean, data will also be the same Bad record http://forexmagnates.com/nfa-fines-fxcm-2-million-for-slippage-malpractices-fxcm-will-credit-clients-back/ Date Time Of Last Edit: 2013-04-16 05:41:33
[2013-04-17 21:23:40] |
C. Notes - Posts: 129 |
I have had 100+ pip data "spikes" refunded on account of bad data... Be careful around FX close, as the spreads can swing out to 20-30 pips and level your stops. For the most part they're not too bad... The SC fix was a great improvement... IB has FX with low spreads... |
[2013-04-17 23:33:28] |
FH87 - Posts: 43 |
These dirty data will affect indicators calculations, very danger! 1 more point the closing of daily price on daily chart is more ridiculous. SO Can Sierra give other choice of free FX data ? Instead of FXCM ? Pls give an answer / response |
[2013-04-19 00:06:15] |
KhaosTrader - Posts: 128 |
I would seriously look into IQFeed, its a good datafeed. They have 2 levels for FOREX, I have them both, but I use the standard feed series.. anyway, I have been happy with them, and they do offer phone support if you have issues...
