Date/Time: Wed, 30 Sep 2026 09:20:09 +0000
SC data Important- Market Depth Data for Market Depth Graph
View Count: 1193
[2020-04-10 12:25:07]
User968625 - Posts: 260
Hello.
the instruction you have for the market depth data on this link doesn't apply to the new version. there is no "Record Market Depth: option is not there (see image)
Market Depth Historical Graph: Step by Step Instructions
see the image
Pls, can you help me how to get this study to work?
imageSymbole settings window.png / V - Attached On 2020-04-10 12:24:28 UTC - Size: 49.57 KB - 426 views
[2020-04-10 13:18:26]
John - SC Support - Posts: 48062
The option for Record Market Depth is still present in the symbol settings. You just need to scroll down to find it. The items are not in alphabetical order, so you need to search through the entire list to find it. We have attached an image that shows it in the list.
imageSymbolSettings.png / V - Attached On 2020-04-10 13:18:19 UTC - Size: 36.74 KB - 405 views
[2020-04-10 15:28:41]
Great. Thank you. one other question, for the number of depth levels, I would like to have as much as I can without impacting performance. wondering if you have recommendations - assuming that I need to fill this in the next row, right?
[2020-04-10 16:39:16]
There are 3 different options when it comes to limiting the Market Depth for performance.
1. Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Max Depth Levels: When using one of the Sierra Chart Data Feeds, this limits the number of levels that are actually received in the system. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels
2. Chart >> Chart Settings >> Advanced Settings 3 >> Maximum Market Depth Levels: This limits the display of Market Depth Data in the DOM. Refer to the information here:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
3. Market Depth Historical Graph >> Maximum Levels to Display: This controls the number of levels that are displayed in the Market Depth Historical Graph. Refer to the information here:
Market Depth Historical Graph: Maximum Levels to Display (0 for All)
Date Time Of Last Edit: 2020-04-11 00:52:16
[2020-04-10 22:46:37]
Thanks. I am going to adjust. if you have a recommendation for how many levels that usually don't affect performance then I would appreciate it. otherwise, I will just try and see
[2020-04-11 02:31:45]
You just have to try and see. We cannot answer that question.
Also you can control the number of market depth level subscribe to per individual symbol. The Symbol Setting for that is currently supported.
Date Time Of Last Edit: 2020-04-11 02:32:04
