Date/Time: Wed, 22 May 2024 01:08:52 +0000
Trying to set up with AMP and CQG
View Count: 505
[2020-04-09 16:27:58] |
User244040 - Posts: 1 |
I've been trying to set up Sierra Charts and am getting frustrated. It says current service package does not support this function but from what I've seen the monthly fee is supposed to be waved when running it through AMP. I have selected CQG for Service under the Data/Trade service settings, and have put in my username and password correctly. Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-04-09 09:48:17.924 * Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-04-09 09:49:43.290 * Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-04-09 10:42:44.110 * |
[2020-04-09 18:49:46] |
Your Sierra Chart account is now active. You should be able to connect now. Instructions: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
