Date/Time: Tue, 21 May 2024 03:25:27 +0000
Bar colour based on previous close
View Count: 1900
[2020-04-08 23:20:21] |
User273624 - Posts: 10 |
Is there a setting where I can set the PRICE bar colour to be based on the previous bar's closed? All I can find is a study that does this for volume bars, and in graphics settings it has an option to set an upbar/downbar colour, except it takes the open of the bar into account. I'm looking for just close-close criteria.
[2020-04-08 23:25:27] |
Ackin - Posts: 1865 |
2 x study: Color Bar Based On Alert Condition Color Bar Based on Alert Condition alert 1 =C[-1]<C alert 2 =C[-1]>C |
[2020-04-09 04:35:02] |
User48838 - Posts: 112 |
Would you be able to create a study to highlight not just the POC of a number bar but also price levels of the next largest volume bid+ask volume and the next highest one after that. TY
POC_1_2and3.png / V - Attached On 2020-04-09 04:34:22 UTC - Size: 33.6 KB - 248 views |
[2020-04-09 12:00:30] |
User48838) If you are register user on CZSK forum you can download - it will be in the update tonight. https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2020-04-09 16:53:41] |
Do those files get downloaded automatically each time i load sierra?
[2020-04-09 18:05:08] |
User48838) If you mean an update - it's not. The library containing the studies is a classic DLL file that you download from our forum, save it in the DATA folder and when you select "Add custom study" you will see it in the list including all embedded studies (more than 180 currently). I do not offer updates automatically, it only brought complications. Everyone makes updates when they need to. |
