Date/Time: Mon, 29 Apr 2024 06:14:41 +0000
Unable To Execute Multiple Contracts
View Count: 2117
[2013-04-15 09:41:08] |
It is not really clear what your Attached Order settings are and what exactly the problem is. Have you looked at this example here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#AttachedOrdersExample2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-20 01:56:07] |
With the Attached Order configuration that we see, as long as the main order quantity is set to 2, you will have 2 Targets and 1 Stop with a quantity of 2.
