Date/Time: Fri, 19 Aug 2022 17:00:46 +0000
IMPORT TICK DATA FILE
View Count: 1063
[2014-01-13 16:57:49] |
User82615 - Posts: 106 |
HELLO CAN ANYBODY SHOW ME HOW TO IMPORT A TICK DATA FILE THAT HAS A CSV EXTENSION? BECAUSE I'M TRYING TO IMPORT ONE AND I CAN'T. I ALREADY HAVE THE TICK DATA FILE BUT I CAN'T IMPORT IT. THANK YOU VERY MUCH |
[2014-01-13 17:20:19] |
You can find the documentation for this here: https://www.sierrachart.com/index.php?l=doc/doc_ImportExport.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-14 13:30:30] |
Could you help me a little more with this please ? I've been trying to import these data and I can't , for example do I have to create a file named :[symbol].scid how can I do this ? |
[2014-01-14 16:51:12] |
No, you just import the CSV file. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/doc_ImportExport.html#import If you still have a problem, most likely it has to do with an incorrect data line format in the CSV file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-14 16:51:26
[2014-01-14 17:19:03] |
I already solved and now I can import the data file, thanks for your help I finally got it I was lost. Thanks |
