Date/Time: Fri, 03 May 2024 08:49:04 +0000
Question regarding Chart Header
View Count: 778
[2020-04-06 13:03:05] |
rainbow47 - Posts: 68 |
Hi, is there a way to see the chart header in multiple lines if not all the information can be displayed due to window size? Thanks |
Capture.JPG / V - Attached On 2020-04-06 13:02:37 UTC - Size: 38.68 KB - 258 views |
[2020-04-06 18:39:30] |
No, this is not supported.
[2020-07-01 15:39:59] |
TeeJay - Posts: 123 |
Would this be a big problem if it would be supported? Thanks |
[2020-07-01 17:05:38] |
John - SC Support - Posts: 31334 |
This is supported now. Refer to this setting: Chart Settings: Autowrap Chart Header (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-01 17:17:27] |
Great, thanks for the hint John
