Date/Time: Sat, 27 Apr 2024 00:56:33 +0000
Amp version: usage time/missing symbol
View Count: 1569
[2014-01-13 16:20:16] |
User025576 - Posts: 9 |
Hi, is the free usage period of the Amp version of SC limited to one month? (activated today, days remaining: 32). Ym seems to be missing in the ttnet symbol list, do I have to update the symbol settings? (full reset or update from server?) I´m also running a fully paid copy of SC. Can I use the amp credentials of the amp version to connect to ttnet with the paid version? Date Time Of Last Edit: 2014-01-13 16:28:38
[2014-01-13 16:27:44] |
YM should definitely be in the list of symbols. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings And then reopen the symbols list through File >> Find Symbol. Your other question needs to be directed to AMP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-13 16:31:58] |
Ok, but will have to wait till 4.45. amp only allows first connect for new users after 4.45. about my other question: will the amp credentials work with my fully paid version of SC? |
[2014-01-13 16:54:56] |
Yes. You can use your AMP account login information with your own Sierra Chart account that you pay for. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/AMPTTNet.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
