Date/Time: Mon, 13 May 2024 23:31:16 +0000
Standard Deviation Bands Study calculation issue
View Count: 1085
[2020-04-05 19:20:31] |
nikos - Posts: 23 |
Good day, I am facing some calculation problems when using the standard deviation bands study and I would appreciate your input. I have set up a "colour background based on alert condition." The alert condition is when the top standard deviation band is less than 3. I put the chart in replay mode and I observe that when there are continuous bars that need to be colored, the program fails to do so "live" but when i hit recalculate it does.... You can check ES futures 3/4/2020 from 15:48 to 15:50 EST for example. Is there any setting I can change in order to have the standard deviation bands calculations correctly plotted? Thanks in advance! when in replay mode http://www.sierrachart.com/image.php?Image=1586114285552.png after recalculate: http://www.sierrachart.com/image.php?Image=1586113977308.png Date Time Of Last Edit: 2020-04-09 06:11:39
Chartbook_test.Cht - Attached On 2020-04-05 19:07:41 UTC - Size: 287.02 KB - 311 views |
[2020-04-09 06:20:22] |
nikos - Posts: 23 |
Hi SC, Kind reminder on the above. Thanks. |
[2020-05-22 03:10:10] |
Will see if we can help with this.
[2020-05-26 01:10:43] |
Sierra_Chart Engineering - Posts: 14341 |
We have implemented a solution to this which will be out in the next release.
[2020-06-02 06:04:27] |
nikos - Posts: 23 |
Good day, Thank you for your effort. I'm currently testing 2115 at the same time/day as the OP and even though it's greatly improved, I'm still getting 2-3 bars not properly calculated. Can you please investigated further? I have set up an automated trading strategy and its very crucial for this. Thanks in advance. Date Time Of Last Edit: 2020-07-30 06:32:35
Paused 1.00X ES-202006-GLOBEX [CB][M] Renko 6t #32 2020-06.png / V - Attached On 2020-06-02 06:01:33 UTC - Size: 53.72 KB - 286 views Paused 1.00X ES-202006-GLOBEX [CB][M] Renko 6t #32 2020-06.png / V - Attached On 2020-06-02 06:01:46 UTC - Size: 53.77 KB - 294 views |
[2020-07-30 06:34:40] |
nikos - Posts: 23 |
Hi, currently on 2138 and still having issues.... Are you willing to investigate further? Thanks |
